Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 12-13-2010, 07:01 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
There are a bunch of threads in the "lowering or standard" section and it sounds like you get exactly the amount of the spacer.
http://www.ramforumz.com/forumdisplay.php?f=24
Old 12-14-2010, 08:42 AM
RichJHU's Avatar
RichJHU RichJHU is offline
Trim Level: SLT 4WD
Rep:89
RichJHU will become famous soon enough
I have looked through just about every thread. Everyone lists the amount of lift but nobody has the dimension of the actual spacer. I'm just going to jack it up when I get home from work today and measure it. Thanks for looking!
Old 12-14-2010, 03:26 PM
CHVYKLR's Avatar
Rep:252
I was talking about height. If you mill some 1" spacers you will get 1" of lift.
Old 12-15-2010, 08:07 AM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
Because of the geometry of the suspension that is incorrect. The A arm attaches to the frame on one end, and spindle on the other. The coil spring assembly is in between. If it was exactly centered then the lift would be twice the spacer.
I checked this when I got home yesterday. I measured the distance from the top of the coil spring to the bottom of the shock mount. Then I jacked the front end of the truck up 2". I measured the distance again and it was 1 1/8" longer. From this I can conclude that the coil spring is slightly closer to the spindle (where the tire connects) than the frame.
For every inch of lift the spacer needs to be 9/16"
Old 12-15-2010, 08:14 AM
CHVYKLR's Avatar
Rep:252
sounds good. good luck with your project. i'm was only relaying real world applications from the numerous people on this forum who have already installed leveling kits.
Old 12-15-2010, 08:29 AM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
I understand that, and thanks for the input. Every model truck is different and in some cases that may be correct. I was hoping that there was someone on here that had a 2010 Ram with a spacer in the front that could measure it. I'm going to make a 1 1/8" spacer and hope it works. I will put pictures up before and after.
Old 12-15-2010, 09:04 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Nice pic of your buried datsun good luck w/ machining your own kit I look forward to pics
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 12-15-2010, 09:27 AM
CHVYKLR's Avatar
Rep:252
Cool. Look fwd to the pics. Always more fulfilling when you can make your own parts.
Old 12-17-2010, 02:27 PM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
Material before machining
Machining
Finished
I am going to try and install them this weeekend!
Old 01-01-2011, 07:53 PM
RichJHU's Avatar
Trim Level: SLT 4WD
Rep:89
Before
After
I finally found some time today to put on my spacers. It took me about 3 hours total and I could not be happier with the way it looks.
