Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum
Old 01-05-2014, 03:00 AM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Default Would Rust Check (undercoating) stain a white RAM?
Hi guys,
Quick Q: With all this talk of things staining the white RAMs, and especially the white flares would an undercoating like Rust Check end up a nightmare?
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-05-2014, 09:06 AM
scottyb's Avatar
scottyb scottyb is offline
Vehicle: 2012 Ram 1500 4X4 CCSB
Trim Level: Laramie Longhorn
Color: Sagebrush Pearl Coat
scottyb is on a distinguished road
I had undercoating added to my Ram and it had some serious overspray. I did bring it right in and had it removed, there was no permanent staining.
The solvent they use to remove it is pretty nasty stuff and you need to make sure they properly seal the paint after they are done.
Old 01-05-2014, 09:15 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Rust check is similar in application to Krown. It drips for a while but will wash right off with soap and water. Now my Ram is black however I have also had silver and blue vehicles done with Krown and the stuff washes right off. Not 100% sure about rust check however suspect it is the same
Old 01-05-2014, 03:36 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
If it washes off with soap and water, if you go through a car wash, won't it wash off the bottom too? *n00b alert*
S S H A D O W
Old 01-05-2014, 04:02 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Where the Krown penetrates is hidden from view and cannot be washed off. I was only referring to any overspray on painted surfaces. They do suggest not going through a car wash for a week following an application. There is a more information on their website
Old 01-05-2014, 04:18 PM
Rep:2657
from the Krown website
Doesn't washing the vehicle defeat the purpose of treating it? (Won't the product wash off?)
After your vehicle is sprayed with Krown at one of our locations, your vehicle receives a wash. We are cleaning the excess product off of the windows and painted surfaces where the product is not active. The rust inhibitor itself cannot be removed from the metal with soap and water.
they also state that it will drip for about 48 hours
http://www.krown.com/value-proposition/
Old 01-05-2014, 05:15 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i always do my fall detail before the trip to Krown. i would suggest a good wax or sealant before the rust check just to be sure. it will be less likely to stain with the added protection if staining does occur.
Old 01-05-2014, 05:21 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
2 comments so far -
First Scotty's photos are scary. Damn. anything that involves 're-sealing' the paint, in my books, is a no-no.
Second, I'm encouraged by the Krown product. As you state it sounds much like Rust Check. If they wash off excess and do a good job then I'd be fine with that.
I've be a little freaked out since I read comments somewhere that mentioned the 'white' flares not being painted, and in fact being white plastic unlike the coloured flares. Which seems to leave them vulnerable to staining because the suspect staining agent sounds like it will penetrate the actual plastic - lacking a protective clear coating etc of a painted product.
Is this true?? ARE 'white' plastic flares just white plastic, that prior to install are NOT painted or treated in any way?
The 'white' flares seem to distinguish themselves this way, from what I understood from another thread.
Thanks!
Old 01-19-2014, 06:26 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Yeah you wouldn't have any issues with rust check or crown. Been spraying my vehicles for years without any issues at all.
