Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
tonneaucovered.com
Old 12-07-2010, 08:57 PM
Dtimekw Dtimekw is offline
Vehicle: 2001 Ram
Color: Blue
Rep:23
Dtimekw is on a distinguished road
Default Heat problem and door blend
I have the same heat problem many of you have or do (no/low heat at idle and gets hotter as the engine RPMs go up) I've searched and read threads until I passed out....wait, that may not have been the reason Regardless, heres a question and hopefully a tidbit to help others. I located the blend door actuator (I hope I called it the right thing). I can see the shaft turn (and step with the temp switch). My question is this....It turns 90* from cold to hot. Is this correct? If so, then I can rule out the blend door not operating. I know it needs to be aligned or zeroed but I would find it hard to believe it would since it just happened. Can anyone confirm the rotation being 90* from hot to cold? Thanks!
Troy
01 Ram Sport, 5.9, Body/Suspension lift on 36's, 4wd
Old 12-07-2010, 09:22 PM
Vehicle: 2001 Ram
Color: Blue
Rep:23
I probably should have mentioned what I have found and am working on. It started after replacing all of the hoses. I didn't check heat for about 3 weeks after. Before doing the hoses, cab temp at the vent and at idle was ~140*. Now, it is 110* and gets to 120* with the engine revving up. I flushed/backflushed the heater core when I did the hoses and replaced the t-stat as well. As of right now, I have the truck on a pretty good incline. I ran it like this for almost an hour the help "burp" it. About every 10 minutes, I would blip the throttle to see if I can hear the air bubbles which I can. At 8 MPG, I decided to leave it overnight on the hill with the rad topped off and the cap off. I'll see what it looks like in the morning. Any other ideas?
Old 12-07-2010, 09:56 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
if you have a locking radiator cap, then burping is just a matter of lifting the lever. I usually run it for a while and then burp it...once or twice is all it takes. Are both heater hoses hot in and out of the firewall?
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 12-08-2010, 05:49 PM
Vehicle: 2001 Ram
Color: Blue
Rep:23
Yes, both are hot. I am not sure what you mean by locking? Do you mean the type that releases pressure by lifting up on the tab? I have the kind that goes on with a 1/4 turn. I am going to try the CLR thing I've read about. Perhaps I have crud caked up in the core.
Old 12-08-2010, 05:54 PM
Resident Technician
Rep:1911
90 degrees movement on the blend door is right.
Old 12-08-2010, 06:04 PM
Rep:2720
to check out your heater functioning correctly, you might look at this site & videos
http://www.heatertreater.net/Dodge%20Product%20Page.htm
Old 12-08-2010, 06:43 PM
Vehicle: 2001 Ram
Color: Blue
Rep:23
Whew! Thanks. saved me some time
Old 12-08-2010, 09:22 PM
Vehicle: 2001 Ram
Color: Blue
Rep:23
**Update** Flushed and backflushed again, this time with CLR sitting in the heater core for 5 mins. By the way, CLR does not recommend using this on copper amongst other things. Just a little heads up. I parked on a hill, burped big blue and managed to achieve 130* with fan on high and engine at idle. This was 20* better than before the flush. I did notice ambient temp has A BIG EFFECT on the temp at the vent. With the hood up I lost ~8* at the vent and noticed my temp guage go down a bit. Good to know. Luckily I am in Fl so it's not as bad as some of you. Hopefully this info helped out!
