Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-07-2010, 09:30 PM
danc danc is offline
Vehicle: 1996 Dodge 1500 Ram
Color: black and silver
danc is on a distinguished road
Default Heat always on
Alright guys here's one. My heater is on all the time. I checked the controls and they all "seem" to work, the blower works like it should, but even with everything turned off (fan, etc.) it gets hot enough that I have to open the windows.
It's not a problem so much now that the bottom has fallen out of the thermometer here in Ohio, but even on 30 degree days it's too hot.
Anyone out there experience the same thing and what's the fix?
Old 12-08-2010, 01:45 AM
lloyd lloyd is offline
Vehicle: 2001 ramm 2500 diesel
Trim Level: full load
lloyd is on a distinguished road
The last vehicle that I had that had an off on the heater control was a1978 Bronco,no AC. I had the same confusion and frustration with my 92 chev 4x4. I think it has to do with AC wether you have it or not. If it is on high always you may have a control rod disconected on heater core that bypasses the coolant as needed. This is generaly located up and under the jockey box. If the heater control has no resistance, I would look there
Old 12-08-2010, 08:22 AM
Thanks lloyd I'll check that out.
