Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
ZDOG
Old 12-07-2010, 11:48 PM
TobyDavis TobyDavis is offline
Vehicle: 2011 Ram 2500 4X4 Mega Cab
Color: Hunter Green Pearl
TobyDavis is on a distinguished road
Default Towing Questin
What weight should I get to before I use tow haul mode?
Old 12-07-2010, 11:57 PM
my09hemi
It all depends on what you are towing and where. Where as in flatlands or mountains. If you are driving and the trans is hunting for gears-it's time for tow/haul mode. I use it everytime my trailer is hooked up, keeps water temp, trans temp, oil temp down. Tow/haul mode sets up different parameters keeping everything in check.
Old 12-11-2010, 11:21 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Good advice.
Old 12-11-2010, 12:04 PM
I agree with what my09hemi says.
When it starts hunting, that's when the constant shifting will start generating heat in the transmission, which is not good. It may not be a heavy load but rather the steepness and duration of the grade which initiates the shifting.
