Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-08-2010, 08:04 AM
NCDEVILDOG's Avatar
NCDEVILDOG NCDEVILDOG is offline
Vehicle: 2001 Dodge Ram
NCDEVILDOG is on a distinguished road
Send a message via Yahoo to NCDEVILDOG
Default Little Heat
Its winter time again, and my heat isnt working as good as it should be. I normally warm my truck up for about 20 minutes before I go to work. The engine temp gets to the 200 degree mark as normal. I have alittle heat, just enough to defrost the windows, but not enough to warm up the cab. Im wondering what could be causing this? Even after driving for abit, or in the middle of the day when its not as cold, the heat still doesnt put out like it should. any incite would be well appreciated.
semper fi to all my brothers out there!
Old 12-08-2010, 08:11 AM
Rep:1909
Are the heater hoses getting good and hot like the upper radiator hose at normal operating temp? I'm guessing tme most likely cause at this point will be a clogged heater core since blend door issues with gen 2 trucks are rare. I would try back flushing the cooling system and even blowing out the core with low pressure compressed air.
