315's - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-08-2010, 04:48 PM
DARB24's Avatar
DARB24 DARB24 is offline
Vehicle: 03 2500 heavy duty
Rep:35
DARB24 is on a distinguished road
Default 315's
i have a 2003 ram 2500 hemi and i currently am runnning 315/70/17 tires by mastercraft, they rub once i get a full turn on the steering wheel.
i just bought some 315/70/17 mickey thompson baja mtz radial which have a bigger tread then the mastercrafts......so i was wondering how many inch spacers do i need to get so they wont rub??
thanks guys dodge ram forum is awesomeeeee
Old 12-08-2010, 07:19 PM
I am running 315/70/17 BFG's . I have a 2" Daystar leveling kit on mine . My r/f would rub on hard right hand turns . I then added a piece to correct it . The rubbing has moved to the l/f wheel on hard left turns . I would recommend to ya to get a adjustable track bar for the front . It may not cure the problem 100% but will definitely help .
Old 12-11-2010, 09:00 PM
ScatPak07's Avatar
Rep:970
If you want to add a spacer you could try a 1/4". That should give you enough if you are rubbing at full lock. I just am not sure since I have not seen the truck and the rubbing.
Old 12-11-2010, 09:49 PM
What he ^^^^ said!
Old 12-11-2010, 09:58 PM
Rep:3337
Yup, the 1/4" spacer should do it, I wouldn't go much more than that though unless you got a full billet bolt spacer.
