Disabling MDS Per Ram Engineers - Page 6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 12-22-2011, 08:46 PM
DWWHemiguy's Avatar
DWWHemiguy DWWHemiguy is offline
Vehicle: 2012 Ram
Trim Level: Express Quad Cab
Rep:37
DWWHemiguy is on a distinguished road
Originally Posted by 2012Rambo View Post
Slightly different on the 2012. The one to the left needs to be followed by one to the right ---> - then + as when you hit it left it selects 5, so to get full 6 speeds you need to hit it to the right after. I tried this yesterday and it never hit MDS and seemed way more responsive. Also I noticed my mpg avg went up from 15.3 to 16.0 over a 60 mile mixed driving run (my usual) but that could be a coincidence.....my truck is coming up on 1K miles so is loosening up a bit which could account for the increase, but then again it could also be that I'm using Shell fuel as opposed to Holtzman (local distributor to my other gas station)......just telling it straight.
Thanks. The only thing is mine is a column shifter. Do I just make sure that I put it in 6th?
Old 12-22-2011, 09:37 PM
2012Rambo 2012Rambo is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Limited
2012Rambo is on a distinguished road
To get full access to all gears yes, you need to select 6th.....mine is the floor shift but it is only selecting the maximum gear you want access to anyway, its essentially a limited auto, but at least MDS is off
Old 04-09-2012, 12:47 AM
triadpc triadpc is offline
Vehicle: 2017 RAM 1500
Trim Level: Laramie 4x4 Crew Cab
Color: Maximum Steel
triadpc is on a distinguished road
Default Best advice to date
This is simply the best advice and tip that I've seen on here to date.
I had taken my RAM into the dealership previously for what I would consider "rough shifting" for the transmission and a "thud" sound coming from the rear end when coming to a stop.
Now, the truck is much more responsive running in "5" and with MDS turned "off", the transmission doesn't try to constantly "hunt" for a higher or lower gear. I also noticed less hesitation, but I'm curious to see how this will affect gas mileage (I currently only get around 14.5mpg in the city and 16 on the highway).
I read in another post that the "thud" noise I was hearing when coming to a complete stop was a known issue with the 32 gallon gas tank, where when full or almost full, the force of the gas in the tank causes a "thud" sound when you stop.
Now, this truck is finally living up to its hype (minus the advertised mpg), and coming from a previous 2x Nissan Titan owner, this says a lot.
Keep up the good word, Dodge/RAM, this truck is awesome. Superchips, if you're listening, we need a dang tuner for our 2011+ model year trucks.
Old 04-21-2012, 09:48 PM
aaronmiiller aaronmiiller is offline
Vehicle: 2006 Dodge Ram
Trim Level: Big Horn SLT
Color: Inferno Red
aaronmiiller is on a distinguished road
Thanks alot for the advice man.
Old 04-30-2012, 08:49 PM
Ram Dude's Avatar
Ram Dude Ram Dude is offline
Vehicle: 2013 RAM 1500 5.7 SPORT
Rep:27
Ram Dude is on a distinguished road
I will be doing this starting tomorrow after I get my Magnaflow installed.........
Old 05-05-2012, 07:48 PM
MILLSRAM's Avatar
MILLSRAM MILLSRAM is offline
Vehicle: 2007 DODGE RAM 1500
Trim Level: 1500
Color: DARK SILVER
MILLSRAM is on a distinguished road
I like useing the tow mode anyway , like the way it holds the shifts at a higher rpm and all, I just deal with the mds if Im on the interstate.
Old 06-03-2012, 04:21 AM
Unknown303 Unknown303 is offline
Rep:27
Unknown303 is on a distinguished road
This is awesome! I was wondering this the other day and at least now I know for sure.
Old 06-04-2012, 11:50 AM
LL247's Avatar
LL247 LL247 is offline
Vehicle: 2014 Ram 1500 QC Sport
Rep:37
LL247 is on a distinguished road
I started driving in tow/haul mode most of the time, I went from hating the transmission to loving it. Seems to hold the gears and not hunt for where it should be.
However, with the MDS you can get awesome mileage on the highway. I drove from Pittsburgh to Atlanta round trip, $220 in gas! At one point the wife called me about 4 hours in and I said "I think my Ram is making gas, I'm not even needing a fill up yet.". The computer said my average was 21.7mpg.
2014 2500 CC Laramie CTD...need me a lift and big 'ol tires.
Old 06-04-2012, 01:22 PM
Rep:2929
I have the 2009 HEMI with the 5 forward gears & then DRIVE, which is 5th Over Drive
While in 5th Over Drive, everything is set up to use MDS, if your vehicle does not need all 8 cylinders, like driving across flat land or going down a grade, but if your going up almost any grade, MDS kicks out & you go back to 8 cylinders
In town i don't use Drive, once i turn onto the highway, i shift into the Drive position
The TOW/HAUL button changes the shifting points to a higher RPM, that way you are using the Torque of the engine to get the towed load moving easier
I have not tried it, but It may also help when you want to go from Light to Light as quickly as possible
Old 07-05-2012, 12:50 AM
EXPRESSIVE EXPRESSIVE is offline
Rep:49
EXPRESSIVE is on a distinguished road
I really don't see the big deal with having the MDS on, maybe if I had aftermarket exhaust the sound mite be an issue. I personally like the sound of my factory exhaust and its no big deal to just (blip) push the throttle down a bit to make it downshift. I do understand that a lot of you are in hilly/mountainous terrain and its probally really noticable but my trips La to Fl are flat ground and I have yet to feel it engage or dissengage!
