Engine Problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-09-2010, 04:07 AM
TwistedCain TwistedCain is offline
Vehicle: 1994 dodge ram 1500
Color: red
TwistedCain is on a distinguished road
Question Engine Problems
i have 2 issues with my 94 ram
first one is my oil pressure drops to zero and my light comes on.. i think this is a electrical problem though because then the light turns off and the pressure jumps back up to normal. and then there are times where the pressure stays normal but the light comes on any ideas?
issue number two is my check engine light is on i did the diagnostic where i turn the key 3x to the on position and then count the number of times the check engine light flashes
the pattern for the flashes are as follow
3 short, pause 5 short, pause 10 short
can anyone help me with the engine code and tell me what the problem is
thank you
Old 12-09-2010, 05:38 AM
Color: red
sorry correction i read the light sequences wrong i have figured out my problems the engine but i am still stumped on why my oil pressure drops and then jumps back up and sometimes the light comes on... its not leaking i cant see any leaks anyways.
Old 12-30-2010, 09:57 AM
MikeCameron1978 MikeCameron1978 is offline
Vehicle: 1996 Dodge Ram 5.2 4x4 Reg Cab
Trim Level: ????
MikeCameron1978 is on a distinguished road
Hey TwistedCain, I had the same thing going on. I was told by the more experienced posters on here that it was probably my oil sending unit. The check was to put a mechanical presure gauge on and see what it was reading or replace the oil sending unit and see if it stops (they are only like $20). The next step is the oil pump which i am now myself going to tackle.
