Old 12-10-2010, 08:56 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Originally Posted by Otterdriver View Post
I can't recall off hand what the lower limit in "kpa" was that set mine off, all I remember reading when I read off in "psi" it was at 34 on the evic display, that's when they started to blink. Now when you say the sensor has not gone off after driving for an hour, are you meaning the blinking hasn't stopped or the blinking along with the low tire insignia on your instrument cluster HAS stopped. All I know is if you take a tire pressure gauge and fill your tires to 40 psi, if that is what's called for on the inside of your driver door and drive it for 15 or 20 minutes, the indication and warning should cease and everything should be normal. Hope that helps. Keep in mind that I have the 265/70R/17's on mine, so 40 psi was recommended, I'm sure that the TPMS is set to that.
Sorry yes I meant the light never stopped flashing the whole time. I have 17's as well, I will try putting 40 psi in tomorrow and see what happens. I didn't know you could top up with air, so that is a lot easier.
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 12-11-2010, 06:37 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
Mine did the same thing this week took it to the dealer they filled them all to 34psi for free the flashing light is off took them 10 mins /no charge
Old 12-11-2010, 08:33 PM
partypooper partypooper is offline
Rep:12
partypooper is on a distinguished road
From the reading on here that I have done it's okay to top them up with normal air (which is 78% nitrogen anyway). That's what I have been doing and no TPMS warning light yet.
OMG!!!11111 If you add regular air to your nitrogen filled tires, it will cause an air bubble inside your tire because nitrogen is heaver than air. Then your tires will be out of balance and you will feel the vibration.
Old 12-12-2010, 11:27 AM
nash211's Avatar
nash211 nash211 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: SLT Sport
Rep:56
nash211 will become famous soon enough
I also had the same issue, added air OK. Happens when it gets colder, I am in the great white north used to Metric. Change it to PSI.
noah12
Old 12-13-2010, 01:03 PM
jj ram's Avatar
Rep:16
Is this true? Can I add air or not? Seems to be quite a few who have added air and didn't notice vibrations?
Old 12-13-2010, 04:03 PM
RamTech RamTech is online now
Rep:1909
Are there any "bubbles" in tthe atmosphere? If I recall correctly our atmosphere is roughly 78% nitrogen and 21% oxygen. The only gas bubbles around the shop today are from a guy that had Mexican for lunch.
Old 12-13-2010, 05:49 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Hahaaha, I just did a 400 mile round trip today, I have added regular air from a compressor to get the correct tire pressure on 2 separate occasions now, trust me there is no vibration...... That was a good one though.
