Old 12-09-2010, 04:11 PM
JDG103's Avatar
JDG103 JDG103 is offline
Vehicle: 2002 Dodge Ram 1500
Color: White/Silver
JDG103 is on a distinguished road
Send a message via Yahoo to JDG103
Default Questions about an electric fan
hey, i saw on trucks this past weekend that they were workin on a dodge ram 1500 with a 360 in it, long story short..hey took out the mech. fan and replaced it with a elec. fan..who has done this and where can i get one, and what size do i need and how much with this cost me
Old 12-09-2010, 09:57 PM
bfinley bfinley is offline
Vehicle: 1997 dodge ram 1500 sport 4x4
bfinley is on a distinguished road
cheapest route is a junkyard/pick and pull. Eary 90`s tarus or mark 8 fan. You will need harness for the fan and some wire. Withe that route you are lookin between 50 and 70bucks
Old 12-10-2010, 07:04 PM
i can give you alittle more info. I went and got my electric fan 2day i got it off of an early 90`s lincolin 3.8v6 2 bolts and unhook the harness and it was out. I gave 26 bucks for it. it has 3 wires a black is the ground a black and orange is low speed and a black and yellow is high speed. I straight wired it to my battery to make sure it worked and on high speed it puts out a ton of cfm compared to stock
Old 12-28-2010, 11:47 PM
Nando Vazquez's Avatar
Nando Vazquez Nando Vazquez is offline
Vehicle: 1999 Dodge Ram
Trim Level: R/T
Nando Vazquez is on a distinguished road
Another option you can go for are two 16" fans of ebay. They range in price depending on the amount of CFM you want from $35-$50 usually with free shipping. There are two ways you can put them in, direct wired to the battery with a toggle switch or with a temp switch & relay. The temp switch and relay with harness go for a bout $35-$50 as well for the dual fan set. They come with a temperature sensor probe which can go in the radiator or block itself depending on where you want it. Flexilite makes an adjustable temp sensor to where you just select the temperature you want the fans to cut in and out of. Plus the fans can easily be reversed from the stock pullers to pushers if you want. Overall a good set of 16" dual electric fans with the temp sensor should run you about roughly $160 with shipping included, the installation should be fairly simple.
Only God Can Judge Me...
