Old 12-10-2010, 01:12 AM
70blackfish 70blackfish is offline
Vehicle: 2004 dodge ram quad cab hemi
Trim Level: laramie
Color: grey
70blackfish is on a distinguished road
Default with 4.56 gear my Speedo is off
what do I change, I have a stock srt-10 rear axle with 4.56 in my truck. I replaced the 9.25. were is the speedo sensor, the one in the rear axle is the stock one from the srt-ram.
Old 12-10-2010, 07:38 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I think you need to use a handheld programmer to update your 3rd gen PCM.
Old 12-11-2010, 01:07 AM
Trim Level: laramie
Color: grey
Default 4.56
Hypertech says theres doesnt work on 2004 model..
Old 12-11-2010, 01:19 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
The dealer can do it, maybe even for free.
Brian:
Old 12-11-2010, 05:13 AM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
when i did my gears the speedo adjusted by itself i dont know about srt axle though
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 12-11-2010, 06:56 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
I was thinking a Diablo Preditor Tuner would work also. Maybe give them a call and see what they think. Might even be able to fool with putting in a different tire size to fool the odometer.
Old 12-12-2010, 12:33 AM
ScatPak07's Avatar
Rep:970
I agree with the above. I have adjusted the speedo with my Diablo Sport Predator by changing the tire size. You can just do that to fool the truck
I really fooled my truck with this. I have 35" tires and I think I set the tire size to 27". The truck reads 24% slower then I am actually going. This is keeping my miles down, just want to make them go up slower hahaha. Only problem is the computer on the truck is all messed up. My MPG reading is horrible since it is all wrong. Doesn't bother me though, as long as I can keep the miles down on the truck I'm happy
Old 12-14-2010, 10:46 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
i dont think there is an easy fix for this as the axle you installed is from an srt-10.....they way the two trucks read speed is different......im pretty sure the tone ring is different......
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-14-2010, 11:40 PM
CHVYKLR's Avatar
Rep:252
Since they take their speed readings differently I would use Scat's advice and trick f*%k the speedo. If your speedo reads fast use a handheld programmer to input a larger tire size. If it reads slow put in a smaller tire size. Drive around with a gps until you fine tune it to your liking. Kinda like using a band-aid for the problem but it'll get you by.
Old 12-14-2010, 11:58 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default to fix the speedo in dash so it reads correct speed
use the preator tuner and a gps, addjust shift points and tire size to get it right
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
