Old 12-11-2010, 10:06 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Default Mag-Hytec installed w/ pics
So after installing the 4.10s and True Trac I really wanted a new diff cover to increase oil capacity to keep any possibilty of higher temps in check. After a little research and reading some reviews I decided on the Mag Hytec. It is an extremely well built piece and features:
• Magnetic drain plug and anodized aluminum dipstick with magnetic insert
• O-ring require no gaskets or sealant
• Routine lube maintenance without removing the differential cover
• 1/8 NPT temperature sender port
• 303 stainless steel hardware
• Lube level reference plug
• Finned aircraft aluminum housing
Fitment is perfect as there is about 3/8" between the cover and the track bar. Installation was really simple (about an hour) and per the instructions. I did have to remove the track bar to get the cover installed. I actually just removed one side of the track bar and pushed it up out of the way.
Capacity now is just over 4 quarts. I will recheck the level today and get a more accurate reading.
Old 12-11-2010, 10:30 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Looks good to me!
Old 12-11-2010, 10:37 AM
NashvilleHemi's Avatar
NashvilleHemi NashvilleHemi is offline
Vehicle: 2004 Dodge Ram
Color: Dark Molten Red
Rep:24
NashvilleHemi is on a distinguished road
Nice!!
Dynomax cat-back, K&N CAI 77series, AFE TB spacer, Trick Flow 20% underdrive balencer, MSD 8.5 wires, e3 plugs, 3865 Super Chips, Fastmans ported TB, 180 T-Stat
Old 12-11-2010, 12:20 PM
Great install!!! It looks good there. Let us know on the fluid measurement.
Old 12-11-2010, 12:48 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
looks good man
Old 12-11-2010, 01:53 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Sweet dude... thanks for the pics!
Dillon-aka, The Little Kid
Old 12-12-2010, 12:31 AM
ScatPak07's Avatar
Rep:970
Yea that looks really good!
I was caught in between the Mag-Hytec and the Oasis diff cover. I chose to go with the Oasis cover with the Ram head in chrome and the rest painted black. I thought it looked pretty cool. The MH looks really good though, great choice man!
Old 12-13-2010, 01:43 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I am definately doing this when i switch out mine dresses up the axle nicely a definate eye catcher.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 12-13-2010, 07:56 PM
CHVYKLR's Avatar
Rep:252
looks like 4 quarts is just about perfect.
there are 2 lines on the dipstick representing low and max levels just like an engine oil dipstick and mine is measuring just above the lower line. If my wallet starts buring a hole in my pocket I'll buy another quart and see how much it takes to raise the line to the max line.
Old 12-13-2010, 08:21 PM
I push the skinny pedal
Rep:3308
Looks good, a little more volume and better heat dispensing is never a bad thing
Kurtis
