Mag-Hytec installed w/ pics - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-07-2011, 07:18 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
I dont know about the overheating of diff oil, or to where it starts to breakdown. I do know that after a long day at work, I went down there to check my exhaust for leaks and touched the diff cover and it does get hot. While I was down there I also discovered a leak of my front seal of the diff. Then again it could of been from abusing the truck at the track doing burnouts at the staging. Over 80 passes Something else I need to care of while getting the rear diff cover and fluids done.
Old 10-01-2011, 08:37 AM
kevster's Avatar
kevster kevster is offline
Vehicle: 2013 RAM 1500 4x4 HEMI CREW
Trim Level: LARAMIE
Color: Mineral grey metallic
kevster is on a distinguished road
I installed the MAG HYTEC on my 2010 Ram 1500 yesterday this is my 2nd M.H. I had one on my 2005 Ram but let it go when I traded truck in, so I used 5.5 qts on the 2005 and did so on my 2010 Ram along with 1 4oz bottle of Mopar limited slip additive. The gear oil says LS for limited slip, I just wanted a little extra inside the housing.,
2013 RAM 1500 CREW 4X4 HEMI LARAMIE. MAG-HYTEC TRANS PAN AND REAR AXLE COVER. BILSTEIN 5100 ADJUST STRUTS, AND 5100 REAR. ENLIGHT AUTO HID KIT. MAGNAFLOW CATBACK. BLACK RHINO SIERRA 20X9 WHEELS WITH ZERO OFFSET, 275 60 20 BACK COUNTRY A/T TIRES. MOE'S 87mm T-BODY. CABIN FILTER MOD.
Old 10-01-2011, 12:01 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
dang..paypal just raised my limit...where can i get the best price for a mag hytec?
Old 10-01-2011, 12:29 PM
Rep:2929
I believe that i bought mine right from www.mag-hytec.com
Dodge #12-9.25
$260.00
Overall height 3 3/8"
Vans, Ram 1500, Durango and some Dakotas
[/IMG]
Old 10-02-2011, 11:49 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I kept an eye on this site and they eventually had a 10% off with free shipping.
http://www.thoroughbreddiesel.com/Ma...diff-cover.htm
Old 10-31-2011, 09:34 AM
thiggins's Avatar
thiggins thiggins is offline
Vehicle: 2012 Ford F150
Rep:44
thiggins is on a distinguished road
Here's mine. It a beautiful piece of hardware.
I ended up with about 1/4 to 3/8" of clearance with the track bar (top bar).
I even hookup up the camper and bounced around with and without the
spring bars installed on the weight distributing hitch. No issues, no leaks, nice...
Really like the cover.
File Type: jpg 2011-10-31_09-03-20_546_Hytec_Diff_Cover_smaller.jpg (120.8 KB, 52 views)
Old 10-31-2011, 12:32 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
Hey Fred check out this link http://www.taperformance.com/proddet...prod=TA%5F1818 I have one of these and not only does it look awesome and hold a little more fluid it strengthens the carrier with the 2 anchor bolts. Let me know what you think, I think it's less $$$ than the mag also.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
Old 11-02-2011, 05:31 PM
XC450's Avatar
XC450 XC450 is offline
Vehicle: 2006 QC Hemi Ram
Trim Level: Lone Star
Rep:37
XC450 is on a distinguished road
Nice addition...may have to be one of my next mods...but after the long tubes go on!
2006 Ram Hemi QC - HemiFever - DiabloSport Predator - Jet 180 T stat - K&N cold air - Pacesetter LTs & Y-Pipe - Flowmaster Hushpower - 5" side exit - 6" lift - 35x12.5x20 Toyo MT - 20x10-24 Fuel Hostage - Summit Racing Drilled & Slotted Rotors - Ceramic Pads
Old 11-05-2011, 04:47 PM
riggz riggz is offline
Vehicle: 2011 Dodge Ram 1500
riggz is on a distinguished road
Just FYI, adding more fluid doesn't help with keeping temps lower. It just delays the amount of time it takes for the fluid to heat up and cool down. Once the fluid has been heated up the only way to cool it down would be to run a cooler or replace the fluid.
Old 01-28-2012, 09:29 PM
sgtwilliams sgtwilliams is offline
sgtwilliams is on a distinguished road
I installed mine today, had to take off the left side of the track bar (top bar) to get the cover on. But I will be honest I let it drain for over an hour and I only got 3 quarts into it. Drove it around and it is still just a smidge over the top (full) line. I plan to drive a bit more tomorrow and double check one more time. my largest complaint is I had the truck in for a recall a month ago. The dealership slathered the RTV on so thick that took me longer to clean than anything else.
So do I go off the dipstick level? Or thew quarts measured in? Or did I not let it drain long enough?
Dang cold in MI to be doing that work today.
