United Radio
Old 12-12-2010, 10:58 AM
lwalston's Avatar
lwalston lwalston is offline
Vehicle: 2010 Dodge Ram 3500 6.7
Rep:93
lwalston will become famous soon enough
Default Headliner
What is the easiest way to run wires above the headliner?
Does the headliner come down?
Les
Old 12-12-2010, 11:04 AM
I would guess along the trim strip at the edges of the headliner. Don't get into the cloth itself. It's a bear to stick back into place!
Old 12-12-2010, 06:41 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Les
Yes. I had some hail damage from the dealer and the dentless repair guy went under the headliner to get them out. If you remove the trim it drops down. You should only need to do (1) side/edge if you're just running wires.
Old 12-12-2010, 08:08 PM
lwalston's Avatar
Rep:93
Thank you Maddog & Barnyard!
I will take a shot at it tomorrow
Les
Old 12-12-2010, 08:42 PM
Good luck, Les!
