Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 12-12-2010, 08:25 PM
jlbf0786 jlbf0786 is offline
Vehicle: 1996 Dodge Ram 1500
Color: blue/grey/faded clear coat
jlbf0786 is on a distinguished road
Default Parking Brake Won't Engage. (NEW MEMBER/1ST POST)
I have a 96' Ram 1500 4x4 (5.9L 360 Magnum) w/ 190,000 miles on her'
The parking brake won't engage when pressed down, it just clicks while being depressed down, and shoots right back up when you remove your foot. And the P-Brake release lever still makes the sound it does as if it were functional ?!?!
____
Also:
Ive had problems with my BRAKE & ABS lights in the Dash staying on constantly for the past year or so. Finally I broke down and bought "what i thought" was the correct parts to fix this and get the lights off.
I replaced:
- ABS SPEED SENSOR (on top of the transaxle)
- EGR VALVE SOLENOID (PURGE VALVE)
*going off the 2 codes that kept reading upon every attempt at passing inspection .. and failing!
At 1st, the ABS light went off until driving it a bit, then it came on and went off again..& (off/on)
The BRAKE light stays on still..
_____
WHATS NEXT?
THANKS GUYS,
jlb-
CHARLOTTE, NC
Old 12-12-2010, 09:31 PM
Sounds like your e-brake cable has broken off or the catch mechanism on the pedal is not catching on the ratchet.
Not sure about the second issue but there are three sensors in your system. Two in front, one in the rear.
Old 02-18-2011, 10:40 AM
coti coti is offline
Vehicle: 1995 dodge ram
Color: green
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
coti is on a distinguished road
mine did that on my 95 ram after replacing rear brakes and a wheel cylinder and whas told to take it to dodge to have the code removed .it wofks fine so I just dont look at it
Old 02-18-2011, 11:57 PM
gwtaz gwtaz is offline
Vehicle: 1998 Dodge Ram 1500
Rep:35
gwtaz is on a distinguished road
I replaced the rear speed sensor and that took care of my problem. My e-brake does the same thing. Makes all the right sounds and actions that it should except it doesn't hold the vehicle.
