Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-14-2010, 08:21 PM
jd322 jd322 is offline
Vehicle: 99 24v ctd
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
jd322 is on a distinguished road
Yes your truck has the on off method. Cycle the key three on off on off on leave it on. Look at the odometer it should show a number there. Most likely it going to show p1963. Or take it to a part store most will scan it for free. Let me know what it says. We will go from there.
Old 12-14-2010, 08:27 PM
DieselD24 DieselD24 is offline
Vehicle: 2001 Dodge Ram
DieselD24 is on a distinguished road
Will do.
Thanks!
Old 12-14-2010, 08:35 PM
Okay, so i just went out and did the 3 cycle method. No code came up, all it said was P ECU than said P DONE. I don't know if hooking up a scanner will help. But, i guess it's worth a shot.
Old 12-14-2010, 09:09 PM
Rep:2625
On most cars, the codes will read out if the engine light is on - all you have to do is put the key into the RUN position.
Normally, to get codes, you put the key on OFF and then rapidly do OFF-ON-OFF-ON-OFF-ON (on some cars you have to do four or five, not three, OFF-ON cycles). On our test 2002 car, the key did not go back to unlock, so it was ACC-ON-ACC-ON-ACC-ON.
You may have to have the parking brake firmly set for the codes to show!
Read more at http://www.allpar.com/fix/codes.html?ktrack=kcplink
just for the heck of it, check your gas cap out, you need a good seal, it can sometimes make your vehicle malfunction, if it is not tight
Old 12-15-2010, 03:31 AM
Tried that as well, and didn't seem to work. Haven't had a chance to check the fuel cap, but i will when i get a chance. I'm trying anything and everything, when i get the chance. Just trying to remedy the problem here.
I really do appreciate the help!
Thanks everyone!
Old 12-15-2010, 03:40 AM
I have been doing a little bit of research and have found out that the vp44 pumps go out often on these model year trucks. I'm beginning to wonder if it's related...
Old 12-15-2010, 11:23 AM
And again, I just checked the fuel cap and it looked fine. I know this might sound kind of dumb but... would an improper seal at the cap cause such a reaction like the one i'm describing?
I almost came close to buying an expensive code reader/scan tool from Snap-On this morning when he showed up at work but, I quickly talked myself out of it as i probably won't ever use it again other than on my own truck.
Probably don't need it, is all i'm thinking...
Old 12-15-2010, 11:40 AM
Vehicle: 99 24v ctd
You could hook it up to a scanner but I don't think it'd needed at this point. It's had nothing to do with a gas cap its not like a car where you have to worry about pressure and evap. These trucks do have a lot of vp problems mostly do to low fuel pressure from the transfer pump. I don't think this is your problem normally if the transfer pump is bad the truck will have a hickup randomly. What it sounding like to me is the chip that was put in is sending an odd signal to ecm. Maybe the map sensor? Also I would take iat sensor out and clean it. you could just shook the chip and see what happens.
Old 12-15-2010, 12:27 PM
I've messed around with it the last few hours and found out none of the features work. I can't adjust fuel pressure, turbo timer, or any of the adjustable features. I'm assuming the chip only turns on when the truck turns on and thats it, nothing more.
I did however, find a disconnected EGT sensor and a plug on the exhaust manifold. Threads look stripped out on the sensor, could be one of the reasons why the chip isn't functioning properly. But, i doubt the chip has anything to do with the issue that i'm having, if it only turns on and nothing else.
Old 12-15-2010, 02:33 PM
Vehicle: 99 24v ctd
The chip probably has a lot to do with it as it is tied into a lot of the sensors and manipulates them to change the fueling of the engine I would disconnect it all together and see what happens. It's possible that it is over fueling at idle because of a false reading.
