Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-15-2010, 06:56 PM
kb9lsv kb9lsv is offline
Vehicle: 2001 2500 cummins, 1998 ram v6
kb9lsv is on a distinguished road
Originally Posted by jd322 View Post
The chip probably has a lot to do with it as it is tied into a lot of the sensors and manipulates them to change the fueling of the engine I would disconnect it all together and see what happens. It's possible that it is over fueling at idle because of a false reading.
i believe you are correct. I have read that some of the quad chips have the high idle feature, and I would bet that is what is malfunctioning. pull the main fuse to it and see if it happens again.
Old 12-15-2010, 10:02 PM
DieselD24 DieselD24 is offline
Vehicle: 2001 Dodge Ram
DieselD24 is on a distinguished road
Well, i found where it's tapped into the fusebox. I will disconnect it completely and go from there.
Hopefully nothing drastic happens.
Thanks again!
Old 02-10-2011, 01:46 PM
wbodine's Avatar
wbodine wbodine is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Green & Gray
wbodine is on a distinguished road
Cycle the key off and on 3 times and it will show you any codes (ie 0244 ) look up the number and your done....Have a pen and paper handy...
Bodine
Old 02-19-2011, 06:27 PM
Solved the issue. I had codes p1693, 0122, and 0123, all related to the APPS sensor. I replaced the sensor, and adjusted the idle voltage and never had a problem again.
