tonneaucovered.com
Old 12-14-2010, 05:41 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Default LSD 3.55 gears
I have 3.55 gears and I heard they were not LSD.It snowed here the other day and i turned off my traction control.Both tires turned everytime I hit the gas. If it wasn't LSD it should be only 1 tire turning right?I can do donuts easy lol.
Old 12-14-2010, 05:43 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Are you sure you have 3.55? If you have the window sticker, it should say what came stock on the truck and what options were added.
Mine was 3.55 but the 3.92s were options that were added at the factory.
Brian:
Old 12-14-2010, 09:36 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
No LSDs with 3.55s. Like RB suggested, I'd double check your sticker or give your VIN to a parts dept guy to check your build sheet.
Old 12-14-2010, 09:44 PM
Ferg's Avatar
Ferg Ferg is offline
Vehicle: 2010 dodge ram reg cab 4x4
Trim Level: sport
Color: deep water blue
Rep:31
Ferg is on a distinguished road
Im 100% positive i have 3.55s and i can do dounuts on dry pavment no prob but a break stand is only a one wheel peel!
Old 12-14-2010, 10:05 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
LSD with 3.92 and 4.10......and 4.10 is only available in R/T
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-15-2010, 05:18 AM
Rep:463
My sticker says 3.55's.When I am on snow and looking at both tires they both are spinning.I don't get on it hard either.I barely touch the gas and both tires spin sitting still.So I don't know.
Old 12-15-2010, 08:53 AM
CHVYKLR's Avatar
Rep:252
just b/c they are both spinning doesn't meen you have an LSD. it could be that the traction control is working or it could be that both tires are encountering the same resistance.
use it as an excuse to pop your cover and change your oil...and to check out the open carrier and spyder gears.
Old 12-15-2010, 10:44 AM
wildcard wildcard is offline
wildcard is on a distinguished road
I have a 2010 RAM RC-SB with 3.55 gears and open diff.
The other day i found on ebay a complete OEM locking diff (LSD) for $285. (http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories)
My question is if thath diff will fit on my truck without modifications or gear changes.
Old 12-15-2010, 10:55 AM
I push the skinny pedal
Rep:3308
Welcome Wild, don't forget to stop by the newbie section to get the official welcome. To my knowledge, the '10s still use the 9.25" rear, so that carrier will work. It doesn't come with any gears, so it should swap in for your open carrier no problem and just reuse your stock gears.
Kurtis
Old 12-15-2010, 11:05 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
As other have said 3.55s open 3.92s lsd 4.10s lsd r/ts try putting one tire in ice/snow one on dry only 1 tire should spin I had an open diff ranger a few years ago and that p.o.s did the same things in the snow that you say your does
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
