Old 12-15-2010, 12:19 AM
garyk garyk is offline
Vehicle: 2011 dodge ram
Trim Level: laramie
Color: grey
garyk is on a distinguished road
Default 2011 ram 2500 leans to passenger side
i just bought a new ram 2500 crew cab diesel two days ago and thought it looked like it was leaning toward the passenger side in the rear. i measured from the bottom of the tail light on each side and the passenger side is 3/4 inch lower than the driver side. the front seems fine.
my wife brought it back to the dealer and they measured and said it was about 1/2 inch but it could be that the box was not evenly fabricated and said to drive it a couple thousand miles, tow etc and then let them measure again. sounded like dealer double talk.
is this something i should be concerned with?
the truck otherwise is amazing!
Old 12-15-2010, 03:15 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z. Personally, I think things I buy new should be correct. That said, I'm really surprised you could spot that small of a lean. I'd suggest measuring from the frame to the ground since that's really your concern.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 09-14-2011, 01:32 PM
Longboom Longboom is offline
Vehicle: 2011 Ram 2500
Trim Level: Big horn
Color: Mineral grey
Longboom is on a distinguished road
Default 2500 leans to pass. Side
My 2500 is doing the same! Been to dealer once w/2500 miles and dealer & rep. Said to drive couple more k miles and maybe it will settle in!! Now I have 5500 on it, goes in Monday! Did they solve yours yet?
Old 09-14-2011, 07:35 PM
Trim Level: laramie
Color: grey
i'm embarassed to say i never followed up on it. shortly after i posted the question, my wife clipped the front corner of that beautiful machine and i lost interest in making it perfect. will be very interested to know what they say and or do with yours. i was kind of worried they might screw it up more by trying to adjust it.
good luck and please keep me posted.
--garyk
Old 09-14-2011, 08:02 PM
Rep:2616
i agree with RootBeer
you would need to measure from identical spots on the body & then do the same on the frame
chances are either way, the shop will just add a spacer of the right thickness to the low side, between the frame & the body, then tell you that it is fixed
what would bother me more would be if the bed were cocked left or right at 1 side at the cab, or if the bed was closer to the cab on 1 side more than the other
Old 09-14-2011, 11:23 PM
hack99's Avatar
hack99 hack99 is offline
Vehicle: 2011 Ram RCSB 4x4
Rep:34
hack99 is on a distinguished road
Maybe the coil not seated properly from factory? I know when I did the lift on my Rubicon, you had to match coil-end to the rubber spacer properly or this might happen. Easy fix either way, as GTyankee suggested, they may add a thin spacer (whatever it's down) to even it up.
Old 09-15-2011, 09:02 AM
Color: Mineral grey
I did mention to the service manager & Chrys.Rep. That all body lines match so it's not a shim issue. Seems like a suspension issue to me. Looking from rear you can see a bigger gap between top of axle to bottom of bumper on driver side as opposed to pass. Side
Old 09-15-2011, 09:11 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
22k miles here and I have the same thing. I can tell b/c the water runs off my tonneau cover and drips down the driver side of the tail gate.
