Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-15-2010, 12:38 PM
Boom8301 Boom8301 is offline
Vehicle: 97 ram 1500
Color: green
Boom8301 is on a distinguished road
Default could use some help
i got a 97 ram 1500 sport. up until two weeks ago heat worked great. i tried topping off the radiator. the heater core hoses are both hot. i dont over heat. i have a little heat when sitting and more when i give gas what could possibly be the problem some insight would do wonders thanks...
Old 12-15-2010, 01:10 PM
tuc0007 tuc0007 is offline
Vehicle: 97 ram 318
tuc0007 is on a distinguished road
Default no heat
I to have the same problem. what i.v done so far is flushed the rad and the core but still the same . I also put some CLR in the rad to see if this would unglog any thing. But to this date still no heat.
The more people i talk to this is a problem with the dodge they have the in let for the core at the top and the gunk keeps building up and cutting off the core usage.
Old 12-15-2010, 03:09 PM
audiophile's Avatar
audiophile audiophile is offline
Vehicle: 1998 Dodge Ram 1500 Club Cab
Color: Blue
audiophile is on a distinguished road
Does the a/c work okay? Can you hear the air doors moving when you switch between hot and cold? There could be a vacuum problem or bad switch. If all of that is working then most likely it is in the heater core. Replacing that is a pain (see my other post in this thread). But I would start with a good flush of the system.
They say hard work never killed anyone, but why chance it?
Old 01-03-2011, 06:26 PM
Tornado39647 Tornado39647 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLE Sport
Tornado39647 is on a distinguished road
What temp is the truck running at when you are driving it? Could have a stuck thermostat in the open position and with the water at full flow it will not get very hot. Just check to see that the truck is still running at normal temp and check the doors for operation like Audiophile stated.
