Check engine light - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-15-2010, 08:46 PM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
Default Check engine light
So the check engine light comes on and off for the past year or so, and everytime I check the code on my superchips tuner it reads "EVAP perge system performance". I told my mechanic this and he said it was probably just my gas cap, so I changed it and it still comes up. Any suggestions or someone who had the same readout?
Old 12-16-2010, 03:12 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Can you put up the exact code?
Old 12-17-2010, 05:44 PM
southpaw5m's Avatar
Rep:23
Hey Dean, I'm sorry Sir I erased the code, but when it comes up again I will post it and get a hold of you. It keeps happening, it's just a matter of time.
Old 12-23-2010, 02:52 AM
wthrmn12 wthrmn12 is offline
Vehicle: 2006 dodge ram 1500
Color: blue
wthrmn12 is on a distinguished road
I get that same code every now and then, I usually take my gas cap off and put it back on and click it a bunch of times and the code goes away
Old 01-24-2011, 11:00 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Mine had the P0441 code. found I had the gas cap cross threaded. Put it on right, light went out. Whoo hoo!
Old 02-02-2011, 06:52 PM
nocoborn's Avatar
nocoborn nocoborn is offline
Vehicle: 2004 Dodge Ram 4x4 Qd Cab
nocoborn is on a distinguished road
definitely had that code lots o times. However, since I've been gripping my gas cap differently (around the outside circumference instead of using the protrusion across the front) it hasn't come up in a long time. I think the torque setting for the break away on the caps is a little week. Try grasping it around the edge, squeezing it hard so it doesn't slip while you tighten it. Seems to work and I didn't have to replace my gas cap. I'm an uber cheap a$$.
Old 02-02-2011, 06:56 PM
There are some vacuum lines that go to the fuel system evap cannister in the front that get old and crack. Sometimes they work themselves loose from the cannister. Either condition will also set that code.
The most common is a loose, cross threaded or failed gas cap.
Old 02-23-2011, 04:19 PM
nocoborn's Avatar
Has there been any recent developments???
Old 02-23-2011, 04:22 PM
southpaw5m's Avatar
Rep:23
Nothing in the last month, I have been really paying attention to making sure the gas cap is nice and tight and making it click once then almost twice. No check engine light yet...so far so good there
Old 02-23-2011, 10:48 PM
nocoborn's Avatar
Awesome. All for the cost of NOTHING!!! Well, maybe a sore wrist from twisting the cap, LOL!
