Old 12-15-2010, 10:27 PM
Momud Momud is offline
Vehicle: 2010 Dodge Ram 1500 4x4 Crew C
Trim Level: Slt
Rep:22
Momud is on a distinguished road
Default Wheel Tire swap - 20's down to 17's TPMS Problem
Me and a friend both have 2010 ram 1500's. Here's the deal. I wanted his 17's and he wanted my clad 20's. All is good on fitment except my TPMS readings are not registering as I am sure his isn't.
Is this a dealer only fix or can I reprogram the TPMS to read the different sensors?
Old 12-15-2010, 11:15 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Were the wheels swapped both from 2010 models? 09 sensors will not work with the 10 model and vice versa.
Brian:
Old 12-16-2010, 12:17 AM
Trim Level: Slt
Rep:22
Ya, Both ares 10's
Old 12-16-2010, 12:26 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Interesting... the quickest, and probably cheapest, way I can think of would be to swap the sensors. Just get a tire shop to break the tires down and swap 'em your old sensors to the rims you traded for and vice versa (unless you have the means to do it yourself of course).
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 12-16-2010, 12:39 AM
Color: RootBeer
Rep:1287
Originally Posted by Momud View Post
Ya, Both ares 10's
Then it sounds like its time to swing by the dealer for a reprogram.
Having the sensors swapped would require removing the wheels from the trucks, dismounting the tires, swapping the sensors, and putting everything back together.
Also the tire shop doing it would have to have the special adapter to work with the chrome clad wheels. Not all shops have it.
Brian:
Old 12-16-2010, 12:46 AM
Rep:147
The adapter is needed to remove the tire from what I understand. The tire would not need removed. The outside would simply need broken off the bead. They wouldn't need to lay the wheel face-down, which is where I understand that the adapter comes into play (for grip when breaking the rear bead seal and removing the tire). It would be a quick job for a competent shop.
Old 12-16-2010, 01:05 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
How far have ya'll driven? I believe you have to maintain 50mph for at least 15 minutes in order for them to reprogram.
If that doesn't work then yes, tire shop or dealer can reprogram to work with your truck without swapping sensors.
Old 12-16-2010, 01:14 AM
Trim Level: Slt
Rep:22
I believe that has been traveled already. Unfortunately, probably gonna have to hit the dealer. Hope it doesn't take em a week like it did to put in my bed liner.
Old 12-16-2010, 08:09 PM
Trim Level: Slt
Rep:22
Ok, I have been told the 20's have a different part number on the sensor than the sensors. That means a sensor swap will have to be done. Hopefully the sensors will be interchangeable rim to rim. Then discount tire will reteach the sensors if they have to.
Old 12-17-2010, 04:39 PM
BobzRam BobzRam is offline
Rep:74
BobzRam will become famous soon enough
I just put on 17s with snow tires in place of my stock 20s. I got new tpms sensors on Ebay for a '10 and all went well. They work fine without any reprogramming. I found out that there are indeed different ones, they go by year and build date, not by rim size.
