What's your take? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 12-16-2010, 12:48 PM
DieselD24 DieselD24 is offline
Vehicle: 2001 Dodge Ram
DieselD24 is on a distinguished road
Default What's your take?
I couldn't find anywhere else to post this so, it ended up here.
There's a lot of skepticism out there about idling your diesel at start-up. I would just like to know what peoples opinions on this are. Many people say different things, and i think it's a very interesting area on diesels that perhaps, some of us don't really think about or care for, especially if you don't know.
People say they idle for prolong periods of time and some say they idle enough to plug in they car charger and start moving.
What it boils down to is... good or bad?
What's your take?
Thanks again!
Dave
Old 12-17-2010, 10:32 AM
Resident Technician
Rep:1915
Extended idling won't hurt the 5.9 the same way it will the 6.7 because of the lack of emission components on the 5.9. It will however waste fuel and increase the possibility of coking the injectors if idled for long periods before reaching normal operating temps.
Old 05-15-2011, 10:22 PM
kb9lsv kb9lsv is offline
Vehicle: 2001 2500 cummins, 1998 ram v6
kb9lsv is on a distinguished road
prolonged periods of idling can cause valves to stick if engine is not at operating temp, allow to idle 5 mins or so when really cold and then just take it easy until up to temp. if you want to idle for long periods then it needs to be idled up to 1200 or so to prevent carbon build up on valves.
Old 05-19-2011, 10:19 PM
FIRESTARTER FIRESTARTER is offline
Vehicle: 98 Ram 2500 CTTD
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
FIRESTARTER is on a distinguished road
idling for prolonged periods of time causes cylinder wash and won't lubricate your motor well and can cause damage.
a lot of people rig a pto throttle on that raises your motors rpm and prevents this.
I usually use my block heater, but won't idle my truck longer than 30 minutes... some people idle them forever
98 12v Cummins Twin Turbo Diesel. Bosch P7100, NV4500, D80h...
