Old 12-16-2010, 12:08 PM
volcom54626's Avatar
volcom54626 volcom54626 is offline
Vehicle: 2006 Dodge ram QC
Color: Brilliant Crystal Black
Rep:17
volcom54626 is on a distinguished road
Default axle wrap!!
So I am pretty sure I have axle wrap now. When I give it gas to take off it makes this horrible clunck, and you can see the axle twist. is there anyway to fix this besides traction bars, or removing the 2" blocks?? I went threw and re tightnend all the nuts on the bolts but still does it! Any help would be appreciated.
Old 12-16-2010, 12:54 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
Sulastic makes some hangers that control axle wrap. New Leafs Would also help. But honestly a good set of traction bars are what ya need.
SUL73NAZ
Old 12-16-2010, 01:10 PM
Rep:17
Damn, that's what I was afraid of! Ha any recommendations? This whole lifting thing is really a pain!!! Haha I might just put it back to stock.
Old 12-16-2010, 02:20 PM
I push the skinny pedal
Rep:3277
It's not that complicated to get trac bars, they are pretty cheap. It's a simple mod, a good kit just bolts on, no welding req'd. Check out caltracs or Lakewood
Kurtis
Old 12-16-2010, 02:35 PM
Rep:17
Got any brands in mind? Only ones I can find for a lifted truck are pro comp and it says 2500/3500, will those work?
Old 12-16-2010, 04:42 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
I had mine custom built. Rize ind makes a good set for your body style. They are for the 2500 as well. I know they bolt up but since your axle tubes may be smalled outer diamter the rear brackets to bolt them to the axle will need reworking. I would contact SDHQ (they are an awesome offroad shop local to you to get a quote on having some made.
SUL73NAZ
Old 12-16-2010, 04:57 PM
Rep:17
what do you think about these, http://www.4wheelparts.com/Lift-Kits...t_pn=EXP72500B
Ya, SDHQ are really easy to work with, I got my cst brake lines from them, and a few other parts. Ill give them a call and see what they say. Thanks SUL, and CD
