Old 12-16-2010, 02:58 PM
muskybait muskybait is offline
Vehicle: 2010 1500 Dodge Ram
Color: Two tone Black/Silver
muskybait is on a distinguished road
Default radio/nav screen visabilty issue....
....it really sucks during the day when I have my sunglasses on.
Anyone have the same problem?
Can we adjust contrast settings?
Thanks Musky
Old 12-17-2010, 08:42 AM
RAM11SPORT RAM11SPORT is offline
Vehicle: 2011
Trim Level: SPORT
Color: BRILLIANT BLACK
RAM11SPORT is on a distinguished road
I have this problem in late afternoon. I leave my head light switch on auto and I find they come on very early and when it does it dims the nav touch screen. I do find it harder to see then. Maybe check and see if yours is stuck in the dimmer mode as if the headlights are on.
Old 12-17-2010, 11:17 PM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
Direct sunlight will wash out the screen much like it does when you try using a laptop outdoors. I think that is more the problem than your sunglasses.
Old 12-18-2010, 08:59 AM
BigJim1500's Avatar
BigJim1500 BigJim1500 is offline
Color: Deep Water Blue Pearlcoat
Rep:59
BigJim1500 will become famous soon enough
Tinting the windows may help. I don't notice the same problem you have, but I've already tinted (50%) all windows... even the rear as the factory tint is just colored glass with no UV or heat protection.
Cheers
[B][COLOR="Blue"][U]BigJim1500[/U]:[/COLOR][/B] 2010 1500 Laramie CC, BLUE, Mopar Tonneau, Short Black Antenna, Lockpick, Pinnacle 50% Tint (all around), K&N Drop-in, Cat-Back in the Spring
Old 12-18-2010, 10:00 AM
Rugged Brown's Avatar
Rugged Brown Rugged Brown is offline
Color: Rugged Brown
Rugged Brown is on a distinguished road
There is a setting on your dome lights just before full on that will increase the brightness setting. Had the same problem myself until I discovered this. Works fine now.
Old 12-18-2010, 01:44 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i dont have this issue but i know you can brighten and dim the settings for the touchscreen in the menue button on the side oif the unit
Old 12-19-2010, 11:47 AM
Tried this but no effect on touchscreen brightness.
Old 12-21-2010, 04:24 PM
I cranked it up to max 10 on the daylight brightness setting and seemed to help a bit.
Thanks....
