Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 12-16-2010, 04:42 PM
blinkram40 blinkram40 is offline
Vehicle: 1989 dodge ram
Color: blue
blinkram40 is on a distinguished road
Default hey, new 89 dodge ram, need help
hello, i just purchased a 1989 dodge ram and it has a few things wrong with it and im not sure about the way to go about them.
the windshield wipers have one speed, fast. how would i go about fixing the speed so they are more usable.
the next issue i have is that to change the gears its a stick that moves to change from like park to neutral to drive. well, the stick does not move inside the dash and have no idea how to get it moving again, it i need to replace dash, or, well i have no idea..
any type of help would be great. thanks alot.
-josh
Old 12-18-2010, 12:55 PM
Ram50Man's Avatar
Ram50Man Ram50Man is offline
Vehicle: 1989 Dodge Ram 50
Trim Level: Standard
Color: Primered Black
Rep:71
Ram50Man will become famous soon enough
not sure about the stick question, but as far as the wipers go, you probably just need a new switch, or wiper motor. I would go to a junk yard and pull a wiper motor and switch off a truck and try that.
'89 Dodge Ram 50: 2.0L, 5 SPD Manual, 2 WD.
Old 12-18-2010, 01:57 PM
Color: blue
ok thanks i will go and take a look for one.
im not a mechanic or anything, this is first truck and still learning alot of terms.
but when you change gears, it says its still in park. like, were its supposed to go to drive, the stick were it says to change gears doesnt move inside of the dash.
Old 12-18-2010, 05:18 PM
Ram50Man's Avatar
Rep:71
ahh ok i know what you mean, i have seen this before a long time ago, but i dont remember how it was fixed.
Old 12-18-2010, 11:38 PM
Color: blue
do you think it requires the whole dash being replaced?
kinda driving by feel right now and kinda sketched out..
and no one has any idea..
is it a part or something? or electrical?
Old 12-19-2010, 12:04 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Ok, first, you do NOT need a new dash. But you do need to be really flexible to get to what you need in order to fix the gear selection indicator.
Most likely you will need to drop (not remove) the steering column because it the indicator is above it.
Get in there with a light and you should be able to see what you're looking for. You may even be able to see what the problem is without removing the indicator housing.
As for the wipers, I'd do the salvage yard thing and get a switch if its a whole lot less than a new switch from the parts store. Like close to free. Otherwise, skip it and get a new one.
Same goes regarding parts for the shift indicator.
One last thing, get a good repair manual for your truck. I've always liked Chiltons personally. Most parts stores have them or you can order one online.
Brian:
Old 12-19-2010, 12:22 AM
Color: blue
ok thanks alot, im not sure what im looking for but im off to canadian tire to get myself a new manual about my truck.
seems not too bad to get all that fixed.
thanks a million, and other sugestions?
