Removal of transmission - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 12-16-2010, 09:44 PM
MrDodge300's Avatar
MrDodge300 MrDodge300 is offline
Vehicle: 1986 dodge ramcharger
Color: Gray & silver
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
Rep:82
MrDodge300 will become famous soon enough
Send a message via Yahoo to MrDodge300
Default Removal of transmission
I am tryin to do a rebuild job on my 01 ram i have instuctions on everything but how to get the trany off the truck, any help?
Old 12-17-2010, 10:29 AM
Resident Technician
Rep:1915
REMOVAL
The overdrive unit can be serviced separately. It is not necessary to remove the entire transmission assembly to perform overdrive unit repairs.
  1. Disconnect battery negative cable.
  2. Disconnect and lower or remove necessary exhaust components.
  3. Remove engine-to-transmission struts, if equipped. Disconnect fluid cooler lines at transmission.
  4. Remove starter motor. Disconnect and remove the crankshaft position sensor. Retain the sensor attaching bolts.
  5. Remove torque converter access cover.
  6. If transmission is being removed for overhaul, remove transmission oil pan, drain fluid and reinstall pan.
  7. Remove fill tube bracket bolts and pull tube out of transmission. Retain fill tube seal. On 4 x 4 models, it will also be necessary to remove bolt attaching transfer case vent tube to converter housing Rotate crankshaft in clockwise direction until converter bolts are accessible. Then remove bolts one at a time. Rotate crankshaft with socket wrench on dampener bolt.
  8. Mark propeller shaft and axle yokes for assembly alignment. Then disconnect and remove propeller shaft. On 4 x 4 models, remove both propeller shafts. Disconnect wires from park/neutral position switch and transmission solenoid.
  9. Disconnect gearshift rod and torque shaft assembly from transmission.
  10. Disconnect throttle valve cable from transmission bracket and throttle valve lever.
  11. On 4 x 4 models, disconnect shift rod from transfer case shift lever.
  12. Support rear of engine with safety stand or jack.
  13. Raise transmission slightly with service jack to relieve load on crossmember and supports.
  14. Remove bolts securing rear support and cushion to transmission and crossmember. Raise transmission slightly, slide exhaust hanger arm from bracket and remove rear support.
  15. Remove bolts attaching crossmember to frame and remove crossmember.
  16. On 4 x 4 models, remove transfer case with transmission jack or aid of helper.
  17. Remove all converter housing bolts.
  18. Carefully work transmission and torque converter assembly rearward off engine block dowels.
  19. Lower transmission and remove assembly from under the vehicle.
  20. To remove torque converter, remove C-clamp from edge of bell housing and carefully slide torque converter out of the transmission.
Old 01-16-2011, 03:49 PM
MrDodge300's Avatar
Rep:82
thanks now i just have to figure out how to gut out and regut the insides
