Old 12-20-2010, 03:02 AM
Chinchilla Chinchilla is offline
Vehicle: 2010 Ram 1500
Trim Level: ST Crew Cab
Color: Deepwater Blue
Chinchilla is on a distinguished road
Default ST upgrade to turn signal mirrors?
I'm curious as to whether my regular heated power mirrors can be switched out to turn signal/puddle light mirrors instead without any electrical mods. Please let me know. Found a killer deal on chrome turn signal mirrors with puddle lamps...
Cortex 91 Octane / 50 Series Flows w/Dual Out Under a Hemi D/O Bumper / Drop-in K&N
Old 12-20-2010, 01:37 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
I believe they can, so long as your existing mirrors have power and heat. Ask Mopar to send you the intructions of the desired mirrors via PDF/fax. They may do this for you and if you get them, the instructions may even indicate what trucks will and will not work. You could also "google" for the instructions - you may run across them. I have the mirrors you are looking for and will see if I still have the instructions. If I recall, all the wiring for the turn signal and parking light was there. I will send the instructions to you if I can find them.
Regards,
SB
Old 12-21-2010, 12:19 PM
Regards,
SB
Thanks Chief! I requested the instructions, but no reply yet, they were quick to get me my build sheet though. Found a pair of those premium turn signal heated puddle lights with chrome mirrors for $200!!!
Old 12-21-2010, 03:49 PM
RootBeer RootBeer is offline
Color: RootBeer
Rep:1287
Seems to me if you pull the interior panel on the door where the mirror mounts you should be able to see connectors there for the turn signals. If they are not there, I doubt you'd be able to do it because your computer may not be able to be programmed to make use of them.
In fact, I'd call the dealer and ask them if they can be installed at all since your truck did not come with them. Lot of times options cannot be installed and programmed into the truck by the dealer.
Brian:
Old 12-22-2010, 12:05 AM
Squeak1964's Avatar
Squeak1964 Squeak1964 is offline
Vehicle: 2010 Dodge ram
Trim Level: TRX 4x4 reg cab
Squeak1964 is on a distinguished road
Where did you find those mirrors for that price?
Old 12-22-2010, 03:39 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Yes, please let me know as well, I am looking for the flip up tow mirrors. Does this style flip like the older mirrors for towing?
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 12-23-2010, 01:21 AM
it is a craigslist deal where the owner received the truck ordered custom, but the dealer sent it with the wrong mirrors. After the tradeout they set them in the cab for him to take home... But, ebay has a partsdirect or directparts e-store that has them for around 226 bucks shipped! not sure if they flip up though, sorry...
Old 12-28-2010, 01:45 AM
I called and nobody at the dealership could answer my question. Anyone with this type/option have a pic of the door internals or side-view mirror connections by chance?
