Old 12-17-2010, 01:35 PM
krafcheck's Avatar
krafcheck krafcheck is offline
Vehicle: 2007 Dodge Ram 1500 4x4
Color: pearl red
Rep:54
krafcheck will become famous soon enough
Default 2007 Ram 1/4" Spacer Results - 2.5" Level/35X12.5 Tires
Installed 2.5inch readylift leveling kit. Got 35x12.5r20 procomp xtreme at's. Before spacers it barely cleared upper control arm and they started to rub the sides of the upper control arm at about 90percent of a full turned wheel and at full turn they rubbed sway bar. Put on spacers and crawled under the truck while son was turning the wheels both ways and no rubbing. it comes close to the upper control arm on the sides but you can see daylight, although not much. I have stock 20's but i think they are the old 20's from 2005 or so but the backspacing i believe is the same as the newer ones.
For future searches with the question of will they fit:
a 2007 dodge ram 4x4 with a 2.5 inch level kit and 1/4 inch spacer will fit with no rubbing or cutting sporting 35x12.50r20's.
Last edited by krafcheck; 12-18-2010 at 12:50 PM. Reason: spelling "of to or" in last sentence
Old 12-17-2010, 02:41 PM
That is GREAT INFO!!!
Old 12-18-2010, 12:48 PM
krafcheck's Avatar
Color: pearl red
Rep:54
Thanks. When it stops raining i can try to get more photos of the upper control arm and sway bar. I took the dodge on a test drive to see if there was any extra unbalance or rumble with the spacers. I could tell a slight rougher ride but it was not that noticeable. given the big more aggressive tires i dont think anyone would notice. there was only one position that the spacers would would go because they were made for 5 and 6 lug. it also appears i had plenty of thread left for the lugs but by sunday night i will check the tightness of the lugs.
Old 12-19-2010, 07:48 PM
krafcheck's Avatar
Color: pearl red
Rep:54
Default side control arm pics
took pics of the upper control arm on both sides at full wheel lock. in one you can see the sway bar. it used to rub but it appears that the 1/4 inch spacer created about 1-2 inches at the sway bar area.
Old 12-19-2010, 08:26 PM
I push the skinny pedal
Rep:3308
Awesome info
Kurtis
Old 12-19-2010, 11:41 PM
Rep:1625
Nice thread, thanks for the info
Old 12-27-2010, 05:32 PM
ThunderedRod's Avatar
ThunderedRod ThunderedRod is offline
Vehicle: 2006 Dodge Ram
Rep:17
ThunderedRod is on a distinguished road
This is the same set up I run and it works great!!!!
K&N CIA, CORTEX, TTI HEADERS AND Y-PIPE, MAGNAFLOW CATS, FLOWMASTER SUPER 44, and more . .
Old 01-15-2011, 05:42 PM
wedgeheaded's Avatar
wedgeheaded wedgeheaded is offline
Vehicle: 06 1500 QC 4x4
Rep:111
wedgeheaded will become famous soon enoughwedgeheaded will become famous soon enough
Where did you get the spacers and are they expensive?
Old 01-15-2011, 07:37 PM
five0addiction's Avatar
five0addiction five0addiction is offline
Vehicle: 2011 dodge ram slt
Color: bright white
Rep:306
five0addiction is a jewel in the roughfive0addiction is a jewel in the roughfive0addiction is a jewel in the roughfive0addiction is a jewel in the rough
good info thanks
MARTIN...THE YOUNG GUN
Old 02-10-2011, 12:46 AM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
Thanks for the info. Where did you get the spacers from?
