Old 12-19-2010, 01:41 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
Originally Posted by gabrieldy View Post
Awesome! that is pretty much all the info I was looking for. I'm new to HEMIs as I've been wrenching on mustangs up until I bought my truck last year. Really glad I did to btw. Way more power and all around value. I was talking to Don and he is supposed to call me back Monday so I'll mention some of this and about the "eagle" heads.
still trying to decide on the cam....theirs or the Comp 260H. trying to stick with a mild cam.
imho......ive found that most shops "custom grinds" are not much more then a comp derivative when it comes to HEMI
ive used the comp in a couple builds and found that compared to similar builds (other people) but using a "custom grind" ive usually wound up a couple tenths faster with the comp (all other things equal)......jm2c!
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-20-2010, 08:54 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
what are the chances any of you guys would have the stock cam specs? would like to compare them to the couple I am looking at and can't decide on. also, I may skip the p&p heads as I'm afraid of losing low end.
Old 12-20-2010, 09:28 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
the new engine being variable vale timing the duration specs are not what you would expect or be able to compare to other cams (see arrington's xe-cam) .....i gave you the lift numbers in a pm....the truck and the car hemi have the same lift but the car hemi has less duration.....
total durationis:
268 intake
290 exhaust
(no idea what it is at .050 which is industry standard)
.472 intake
.460 exhaust
hope that helps.....by the way if you use an older cam i think you lose vvt...someone please correct me if im wrong there....
Old 12-20-2010, 09:44 PM
CHVYKLR's Avatar
Rep:252
I'm really confused now. I called comp today and the guy recommened a cam I hadn't even looked at.
Choices:
Arrington cam like Autobred bought.
Comp TPX 254HR 15
Comp TPX 262HR 14
Comp 260H 11
Old 12-24-2010, 01:36 AM
hemiram66 hemiram66 is offline
Vehicle: 2004 Dodge Ram
hemiram66 is on a distinguished road
Wait, you could get a 12:1 compression ratio! Is it even safe to run that in a hemi?
Old 12-24-2010, 07:28 AM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
Choices:
Comp TPX 254HR 15
Comp TPX 262HR 14
Comp 260H 11
Have you talked to Inertia Motorsports?
http://www.inertiamotorsports.com/camshafts.html
Ive seen threads of them testing on 09+ vvt motors that are almost 2 years old.
