Old 12-18-2010, 04:23 PM
lpgramman lpgramman is offline
Vehicle: 2010 Dodge ram
lpgramman is on a distinguished road
Default tranny problem PO 0933
Hi , i,m hoping someone might be able to shed a little light on this one.
We have just converted a 2010 Ram 5.7 to LPG, driving it back to the customer i noticed the gearbox was not shifting properly,it seems to pull away in 2nd and goes int 4th i think.it has no kick down either and the manual gear selctor does,nt work
it had 2 fault codes logged PO 0933 ... PO 0731 [from memory]
The first code is a hydraulic pressure sensor circuit failure.
Any help gratefully received
cheers
Old 12-18-2010, 05:33 PM
Rep:1882
Was any work done that could have resulted in damage to the wiring to the transmission?
Old 12-19-2010, 12:24 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
cheers
the first code can cause the second code.....always check fluid level! but if you havent hurt any electrical connectors p0731 could indicate (most times) the trans is slipping.....basically it means "gear ratio error in 1st"....p0933 is "hydraulic pressure sensor range/performance"......right now the vehicle is running in limp mode......
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-19-2010, 04:38 PM
hi , thanks for the reply, we dont go anywhere near tranny wiring or plugs, all our wiring is done at the ECU.All the wiring we use is documented and used repeatedly on all our conversions.
My own thought is that it is just coincidence,
thanks again.
Old 12-20-2010, 01:26 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
thanks again.
possibly but doubtful.....even with all your wiring at the pcm its easy enough to damage trans related wiring as the pcm (ecm as you called it) is the engine controller and trans controller.....5v reference is shared with trans/engine sensors....such as app sensor,map sensor,and cmp sensor in this situation....they all begin at pcm C1 harness connector yl/pk wire pin 27....
if this truck didnt have a problem when it got there its related to something you guys did imho......
Old 12-23-2010, 05:58 PM
i have double checked all the wiring , plugs , pins, etc and all seems wel.
i have spoken to a guy who does a lot of work on Rams, his opinion is there is a fault within the tranny, a module.
Its in with a mercedes dealer at the moment ,so we will fgind out soon enough.
i,ll post up the outcome.
thanks again
Old 12-23-2010, 10:11 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
thanks again
why mercedes......
Old 12-24-2010, 05:25 AM
why mercedes......
They are also Dodge and Chrysler dealers in the UK.
