Old 12-18-2010, 06:19 PM
10RamFoose 10RamFoose is offline
Vehicle: 2010 Ram 1500 crew cab
Trim Level: SL
Color: Mineral Gray
10RamFoose is on a distinguished road
Default 35in tires and a working ECO???
I just bought a 2010 Ram crew cab with the 5.7L. I want to lift it about 4in and put 35in BFG All terrian tires on a 20 rim on it. My concern is that doing so will make the fuel saving system (eco) never kick on. Would that be the case? If so I might have to look into smaller tires. Whats the best approach?
Old 12-18-2010, 07:22 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 2014 Ram 1500 Quad
Trim Level: Lone Star
Color: Blue Streak Pearl
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
With or without ECO, your mileage will drop with 35's. Plus, the 'all-terrain' never was worth much for MPG. (Great for a lot of things, but MPG ain't one of em!!!)
You may consider a gear change. ECO is not as HUGE a factor in MPG as some would like to believe. Yes, it helps, but it's not gonna get ya 10 MPG better,,, or 10 MPG worse,,,
Old 12-18-2010, 08:39 PM
It should still work. Your RPM's won't jump that much!
Old 12-19-2010, 07:36 PM
CHADDER03's Avatar
CHADDER03 CHADDER03 is offline
Vehicle: 2009 Ram Quad Cab
Rep:29
CHADDER03 is on a distinguished road
well im on 37's and my eco still works
Old 12-20-2010, 03:05 PM
keithh2oskier keithh2oskier is offline
Vehicle: 2010 Dodge Ram 1500 4X4
Color: Inferno Red
keithh2oskier is on a distinguished road
On my 4.7 the Eco only comes on when light throttle is applied. I would estimate it at under 10%. I don't have cylinder deactivation like the hemi but I think the Eco is pretty worthless on my truck.
Are you referring to the cyl deactivation still working with 35s?
