Old 12-18-2010, 09:25 PM
danfo danfo is offline
Vehicle: 2000 Dodge Ram
danfo is on a distinguished road
Default Cannot read engine codes
The check engine light on my 2000 Ram 5.2 came on today. I stopped by Auto Zone to get the code read and when they plugged the reader in it would not come on. They said I probably had a fuse somewhere that was blown but I cannot figure out which one it could be. Has anyone seen this and could help me.
Thanks
Old 12-19-2010, 03:54 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Try the key dance to see if their scanner had a problem. Key off, key on X3, codes will show on the odometer. Might also want to post up miles and any service history with the code.
Old 12-19-2010, 09:53 AM
I was thinking the key dance only worked on 97 and older.
Old 12-20-2010, 01:58 AM
Color: Garnet red
Rep:202
Works on my 01.
Old 12-20-2010, 10:01 AM
Works on my 01.
thanks, crab man for the help, it did work and the error code was that the engine did not come up to temp fast enough. I may have to replace the thermostat if this continues to happen.
danfo
Old 12-20-2010, 10:57 AM
Rep:1845
danfo
Sounds like a stuck open stat to me. The only fuse providing power to the DLC also powers your radio, power mirrors, and interior lights. If it's a blown fuse, then you'll notice a problem with these things as well.
