Old 12-19-2010, 08:06 PM
redram1500 redram1500 is offline
Vehicle: 98 Ram 1500 St. Cab Lg Bed
Color: Med. Red
redram1500 is on a distinguished road
Default 2WD Ram 1500
Ok, this could be a dumb question. Why is it that only one wheel turns?
Here how I found out. I just installed a small personal plow on my truck. I stopped on an icy patch with one front wheel down off my gravel drive just enough i was having trouble getting it out. I put my wife in the truck and threw some cat litter under the tires for traction and had her back up. I noticed as she backed up that only the driver side rear wheel was moving as it spun a bit before catching traction.
So, is this normal? Do I have an issue? I just got the truck used a few months ago and it runs great, just noticed this and I feel it could be a problem as I have a very long wide driveway, hence why I got a small plow and not a snow blower.
Thanks for any help, ideas, or even if I'm just dumb and this is normal.
Old 12-19-2010, 08:07 PM
Normal for most light trucks. It's an open differential. You can convert it to a limited slip or posi with a new gear set or a locker set from Detroit Locker.
Old 12-19-2010, 08:59 PM
Color: Med. Red
So that was a bit over my head. I think I understand open differential...that makes one wheel move. What is the difference between limited slip and posi and which would be best for my application of light towing and light plowing?
Also, how hard is it to install a new differential? I'm new to trucks but I'm pretty good with auto repair and maintenance.
Old 12-21-2010, 08:50 AM
Color: Med. Red
Ok, so I did some research on the differential differences. I think I have a pretty good understanding of them now. That leaves two questions.
1. How hard is it to change a differential?
2. Is it worth it for light duty plowing and towing?
Old 12-21-2010, 08:13 PM
96DodgeRam1500's Avatar
96DodgeRam1500 96DodgeRam1500 is offline
Vehicle: 1998 Dodge 2500 4x4 Sport
96DodgeRam1500 is on a distinguished road
First of all, welcome to the forum...
Its not hard.. Its pretty simple and it can be done with basic tools.. I personally think posi would be best, thats what Id go with. Considering your going to be plowing so your going to want to be sure you always get traction..
And if you have the money then I would say it would be a good investment.
1998 Dodge Ram 2500 Sport 4x4. 360 all stock. Leveling kit with 315s.
