Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-20-2010, 12:56 AM
darnold76 darnold76 is offline
Vehicle: 2000 Dodge Ram
Color: blue/silver
darnold76 is on a distinguished road
Default hot or cold
I have a 2000 ram and the heater either blows full hot or full cool, no matter which location setting it is on it will either blow very hot or cool (no heat at all). temp changes to full hot at about halfway when you move from cool, and goes to full cold at about 1/4 from cold when moving from hot. HELP please!!!
Old 12-20-2010, 10:01 AM
Rep:1885
The blend door is cable controlled. If you remove the glove box, you should be able to see where it hooks to the blend door in the HVAC housing. Check and make sure the cable is attached properly and that the door moves and stops in all positions between cold and hot. The door should have about a 90 degree range of travel.
Old 12-20-2010, 09:41 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
If that doesn't work, you may have to look at the check valves in the engine bay. They are on the passenger side on the vacuum lines coming off the intake.
www.beatcraigslist.com - for posting dangers & secrets
