Old 12-20-2010, 03:14 PM
Walkj60 Walkj60 is offline
Vehicle: 2009 Dodge Ram
Color: Sand
Walkj60 is on a distinguished road
Default Radio locked display and cant shut off or reboot!
I have a 2009 Dodge Ram 1500 Laramie. The radio just "hung" while I was talkiing on the phone through the Blue tooth feature. It is still hung now and wont react to any buttons I push. I turned off the engine and removed the key fob from the ingintion and opened a door to turn off anything that runs for a short time. But, the radio is still "hung" and the display is on and won't shut off. I'm concerned it will run down the battery if I don't do something about it.
Has anyone had a similar instance? Does anyone know how to "reboot" the system, like when you restart a computer?
Thanks for any help anyone can lend.
I am editing this post because after checking it again the radio seems to be fine now. But something else that is diferent than normal. Once it is started using the remote start feature, it shuts on as soon as the key fob is inserted into the dash.
Thoughts anyone?
Thanks.
Old 12-20-2010, 03:22 PM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
Pull the radio fuse?
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 12-20-2010, 03:26 PM
blue09's Avatar
blue09 blue09 is offline
Vehicle: 2012 Ram 1500cc
Rep:19
blue09 is on a distinguished road
i have trouble with my radio often. sometimes when i start the truck it will not turn on, the only thing it will do is eject a disc or load one. I have to unhook the negative battery cable for a few seconds, then start up the truck and everything works again. On the plus side it also resets your fuel computer and your gas mileage is much better. Try it and i hope it helps you.
Old 12-20-2010, 05:25 PM
Rep:2657
If i remember correctly, there is a fix for those radio problems, i believe it was a TSB (technical service bulletin), about it.
Just tell your dealership about it & they should get you the updated version software
*Has lock up bug for CAN C vehicles (unknown at time of release)
No new features however bug fixes include:
Muting of VES 2
VES browsing
New AAC decoder improving reliability
Juke Box Random mode behavior
Phone display screen behavior
Graphics if USB removed during copy
Voice Recognition interaction with Steering Wheel Controls
FF/FW graphics in HDD menu
Added progress bar to USB copy
Update EQs for non amplified system sound performance
Gracenote August 2006
Fix for CAN C vehicle lock up bug on Ignition on
Old 12-20-2010, 05:38 PM
Color: Sand
Thanks all for your ideas! I appreciate your quick responses.
Old 12-20-2010, 05:49 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
GTYankee is right on, I had the Mygig in a 2009 300 and it was locking up as you have described. I'm assuming you have the mygig unit. The fix was a software update that I was able to download and put onto a DVD. The dealer would also be able to do this. Good luck and let us know how you make out.
Old 12-20-2010, 07:52 PM
gerbie28's Avatar
gerbie28 gerbie28 is offline
Vehicle: 2009 Dodge Ram 1500 4x4
gerbie28 is on a distinguished road
Its happened to me on many ocassions where it would just freeze and didnt shut off i went to the fuse box and pulled the fuse and re-installed the fuse and bingo its worked again
Old 12-28-2010, 03:20 PM
Color: Sand
Little update, since the problem occur a few days back its been working as normal. My dealer ordered a CD to update the radio but it ended up being the one for the raadio without Nav and touch screen? So they told me they will make a few calls, but if its easy to download from the internet I should be able to burn it to a disc. I just need to figure out where to download it from. Thanks again from all the help everyone!
Old 01-02-2011, 10:25 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
I have a problem with my Radio/CD player...the face won't come down unless you push the open/close button 10 times and when it does come down and I insert a CD it won't recgonize them. I have an appt tomorrow with the dealership. Not sure if you're having that problem or not.
Old 01-03-2011, 11:29 AM
Color: Sand
No, I havent had a problem with the face opening/closing.
Since my last post I did download an update, burned to a CD and updated radio myself as a few folks here mentioned. I'm not sure if I'll really ever know if the update helped my problem since it only happened once, but I'll figure it did if it never messes up again.
I also downloaded a "Gracenotes" update (which takes a DVD disk because its so large), and I plan to update it later today. I'm told its to update the database, and that it provides information for song titles that may be missing, and maybe other info, to songs copied to the hard drive.
My radio is the MyGig RER model. The link where I got the downloads,in case anyone needs it, is below.
http://mofv.com/mygig/
I hope this inforamtion helps others as you folks have helped me. Thanks again to you all!
