Old 12-20-2010, 03:34 PM
02blue ram 02blue ram is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Trim Level: Basic
Color: Dark Blue
02blue ram is on a distinguished road
Default Whats gears?
Hey guys im new here and im trying to find out some info on gears. i have an 02 dodge ram 1500 4x4 standard cab with a 4.7 and stock 3:55 gears i put 33" nitto mud grapplers on it a couple years ago and havent had the time or money to do gears untiol now. First question is where do i get an 8" front case so that i can fit 4:56 gears and the second question is 4:56 gears overkill or should i go with the 4:10.
Thanks
Nick
Old 12-20-2010, 05:09 PM
Rep:1885
I'd go with 4.10's if you want to keep anything that resembles gas mileage.
Old 12-20-2010, 08:00 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
No need to go to 4.56s.
Brian:
Old 12-20-2010, 09:32 PM
I agree! No need for 4.56's unless you plan on some rock crawling.
I have not seen a case specifically for your application but I haven't looked that much for one. I'd try 4wheelparts.com or call a local trans/differential shop to see what they know.
Old 12-21-2010, 12:06 PM
Trim Level: Basic
Color: Dark Blue
ok i figured the 4:56 might be a bit much but it seems like alot of the guys are going with them. my local shop said all i need to do is get an 8" carrier for the frt diff
Old 12-21-2010, 07:47 PM
ScatPak07's Avatar
Rep:970
I have to agree and say go with the 4.10 gears in the truck. It is a big enough difference from the 3.55 that you would notice. And like the others said it will be less of a pain on the MPG then the 4.56 gears. If you had 3.92 gears then I would say go with the 4.56 gears
Also make sure you do the front and rear gears. Dont just do one diff or else you wont be able to use your 4x4. Just thought I would mention that to be safe.
Old 12-21-2010, 08:18 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
If you think you might go to a bigger tire sometime down the road I'd go 4.56s otherwise 4.10s like everyone has suggested.
Old 12-21-2010, 09:27 PM
TheSatinPumpkin's Avatar
TheSatinPumpkin TheSatinPumpkin is online now
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
For a 4.7 4x4 with a lift and 30"-35" tire diameter i would do 4.56's. Yep you will need gears for the corp 9.25 rear and 8" IFS front axle.
Difference between 4.10's and 4.56's is about 200rpm. Save MPG then don't drive 75+
