Old 12-20-2010, 07:01 PM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Lifting the 2001 Ram...which lift?
I'm thinking about going 3-4" lift on my 01 Ram...not sure which company to use since i've heard lifting this particular truck past a certain point requires you to change a lot of components...i dont want to do a spacer lift i'd prefer the coil spring set up...anyone have a suggestion for a complete lift kit?
Thanks
Old 12-20-2010, 10:08 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
Top Gun Customz specializes in lifts for solid axle trucks like ours. They can assemble a complete kit for you (part by part) with many options. I would give them a call.
SUL73NAZ
Old 12-21-2010, 04:52 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
I can get you a deal on a BDS lift.They are really good lifts.I have a BDS 6" on mine and I love it.
Old 12-21-2010, 10:34 AM
alfonso318's Avatar
Rep:42
Id love to go BDS but it think they're outta my price range...im thinking somewhere under $600 for the lift...
Old 12-21-2010, 12:58 PM
Rep:463
Ya I can't go that low on a BDS kit for you bro.I can pull strings but 600.00 is really low for a suspension lift.
Old 12-22-2010, 03:29 AM
alfonso318's Avatar
Rep:42
Yah i know...i think the only one i've found is probably a RC or TopGun... i'm not looking for a huge lift but i would like to fit some 285s or a lil bigger with out having rubbin problems cause i hunt and drive through fields quiet a bit...i love my clearance...
Old 12-22-2010, 04:39 AM
Rep:463
Well you could do Bilstein 1500 series struts which will lift your nose 2.5".Then if you want more lift you can get a 3" body and you will have a nice lifted truck cheap.
struts around 200.00
3" body around 400.00
There is your 600.00 lift and you could put 35" tires on her.Minus the cost for install.
Old 12-22-2010, 06:58 PM
alfonso318's Avatar
Rep:42
Im not sure my truck qualifies for those ride height adjustable Bilsteins...is that the same thing you're talking bout with the struts?
I really dont care for the body lift...
Old 12-22-2010, 09:41 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
He has a solid front axle truck so the struts won't net him any lift or work.
You could hit up top gun customz for a 3" lift with coils and shocks. You can upgrade the shocks to bilsteins and still be around $600 Here is a link:
http://www.topguncustomz.com/Store/G...iview=25474016
You might be able to squeeze 35's under there depending on your wheel and tire combo
SUL73NAZ
Old 12-23-2010, 12:15 AM
alfonso318's Avatar
Rep:42
What about this lift...thought it was a pretty complete deal...maybe pick up some upper and lower control arms???
http://www.4wheelparts.com/Lift-Kits...7&t_pn=SUPK331
thanks for the advice
