Old 12-25-2010, 11:53 PM
Daddy454 Daddy454 is offline
Vehicle: 2010 Ram 1500 SLT 4x4
Color: Inferno Red
Daddy454 is on a distinguished road
Here's some pics of an Inferno Red before and after....
Old 12-26-2010, 12:01 AM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Now you need to debadge it. Blackout removed looks real nice btw
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 12-26-2010, 01:43 PM
diaster's Avatar
diaster diaster is offline
Vehicle: 2011 Dodge Ram 2500
Rep:46
diaster is on a distinguished road
here is a pic of white from online
Old 12-26-2010, 01:54 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Nice guys! I'll rip mine off in a bit and post pics!! Bright Silver Metallic!!!
Old 12-26-2010, 02:57 PM
2010 HEMI SPORT's Avatar
2010 HEMI SPORT 2010 HEMI SPORT is offline
Vehicle: 2010 RAM HEMI SPORT
Trim Level: SPORT
Color: MINERAL GRAY
Rep:62
2010 HEMI SPORT will become famous soon enough
THANKS MARTKOS...
looks great, now i gotta go do my mineral gray sport...
Old 12-26-2010, 03:00 PM
diaster's Avatar
Rep:46
Newbie here with my first how to. I have done several mods to my Harley Road King, Chevy Avalanche and late model Vette; from lighting to body work so now here we go with my first with the Ram.
Just finished. The time it took was 1 hour and 15 minutes from getting the tools to putting it all away, polishing the door (by hand) and uploading photos and writing this post :-)
Good luck i think it was worth it
Before I started
After
in process front door
Peel edges up first, note screw removed, both doors have one. Front door is in the rear, rear door is at the front ...
In process back door, pull the rubber molding out of the way, as well as remove the lower screw holding the door trim in place
Final result
I used a pro paint stripper heat gun on low setting, in December outside temp. was about 49 degrees. Keep the sticker warm enough that your hand is uncomfortable in the hot air but tolerable. You will have little to no left over glue. It should be a firm pull but the material still somewhat stiff.
The more angled the pull, i.e. back on itself the better the glue will stay with the material. 90 degree angle or less and the glue will tend to stay on the vehicle.
Hope this helps
Old 12-27-2010, 04:48 PM
916Timmy's Avatar
Rep:1443
Nice job Diaster!!! I'll do mine here in a sec!!
Old 12-27-2010, 05:35 PM
916Timmy's Avatar
Rep:1443
Talking
All done!! 30 minutes!!! Used the hair dryer and pull on both sides evenly, strait down and it won't leave hardly any residue. I had a little on the edge where the window is, but it rubbed off without any goo gone!!!
Old 12-27-2010, 06:11 PM
Outlaw's Avatar
Color: Bright white
Rep:435
Before I started
After
Final result
Hope this helps
75 min to do this?? your kinda slow. i did mine in 20 min counting removing the screws
oh it looks more better btw!!!
[/CENTER]
Old 12-28-2010, 01:47 AM
diaster's Avatar
Rep:46
no 75 minutes, to move the truck intio the drive, go get the blower and screw driver, pull the material, take the pictures, edit the pictures, upload the pictures, wipe everything down, smoke a cigar and write and edit the post. actual removal time i would guess at about 5 to 7 minutes a side. BUt I was in a documentation mode... not a race :-)
