Old 12-21-2010, 03:07 PM
THE RAM MAN THE RAM MAN is offline
Vehicle: 2007 Dodge Ram 1500 5.7hemi
THE RAM MAN is on a distinguished road
Default ZEITRONIX 5.7hemi?
hey every one i was wondering does the zeitronix system work with my stock ecu. and if so can i tune fuel/air/timing or is this just a logging system
try and ignore my stupidity iam a newbie thanks alot for any info
Old 12-21-2010, 03:12 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Have you checked our section on the Diablo tuners? They do not leave an electronic footprint if you need to uninstall it before having work done at the dealer.
Brian:
Old 12-21-2010, 03:28 PM
thanks for the reply. no warranty to speak of. iam trying to get rid of a p0430 code and have the tuning capabilities to install cams/adjust air/flue ext. thanks again Aaron
Old 12-21-2010, 10:30 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
there is a flash available for that code......cat efficiency....of course you may have a real issue but thats where you need to start....
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-21-2010, 10:33 PM
The Zeitronix system is a data logger, not a tuning tool. But it's a NICE data logger, IMHO. I know a lot of HEMI owners who use them.
Old 12-21-2010, 10:48 PM
thanks a lot any idea's what some of the real problems could be... also no sure what a flash is but iam interested in installing a wideband and have tuning capabilities i have been looking at the AEM fuel/ignition controller-8 any thought or info thanks
Old 12-21-2010, 10:57 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
I know it will for a 04. You can't use it to tune but you can datalog/graph the logs (AFR/RPM commonly for NA) and provide them to your tuner.
Old 12-21-2010, 11:03 PM
Color: Satin Orange
Rep:597
I used non foulers (no cats) which worked for a few years but then i ended up having my tuner disable my rear o2's within my custom tune.
