Old 12-21-2010, 07:25 PM
m1haley m1haley is offline
m1haley is on a distinguished road
Default rear springs
Has anyone changed rear coil springs on the 2010 bighorn 1500 crewcab ?
Seems to be a little soft when loaded.
Old 12-21-2010, 09:23 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Not sure if there is an aftermarket coil of factory height that is rated at a higher spring rate. What most members here seem to do is buy the Airlift 1000 or Firestone airbag kit which installs inside your coil.
I've bought the Airlift kit but have not installed it yet. These kits do not increase your payload but prevent the rear from squatting like you are experiencing.
Old 12-21-2010, 10:33 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
yeah they softened up the ride with the springs over leaves. they do sag a bit when loadedbut like he said some airbags in the springs will prevent that.
Too many mods to fit here!
Old 12-22-2010, 01:00 AM
Otterdriver's Avatar
Otterdriver Otterdriver is online now
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
If you want simplicity, look up Timbren suspensions, no airlines to route, or leak for that matter, all you do is remove the factory bump stop and replace it with the timbren suspension designed for late 09' or 10' trucks. It rides about an inch above your axle, so it doesn't compramise your ride empty, until you throw a load on, your suspension will never squat again.
Old 12-22-2010, 01:23 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
That's good info right there ^^^
Old 12-22-2010, 11:00 AM
deepblue's Avatar
deepblue deepblue is offline
Trim Level: Quad Cab Sport
Rep:65
deepblue will become famous soon enough
A little illustration for those trying to visualize how these work:
Build Date: MDH:052720 [May 27th (Thursday), 8PM -- 2010]
2010 RAM Sport - Deep Water Blue, 3.92 Gears, Flowmaster 40 Series, Volant CAI w/PowerCore, BedRug, BakFlip F1, Bilstein B6 HDs
-cc
Old 12-22-2010, 06:40 PM
Thanks, for the info I'm looking up Timbren Suspensions now
Old 12-22-2010, 08:46 PM
yagottaregatta's Avatar
yagottaregatta yagottaregatta is offline
Vehicle: 2012 Dodge Ram
Color: Deep Cherry Crystal
yagottaregatta is on a distinguished road
I have the timbren setup and love it.
BedRug, Bakflip Tonneau, Moroso Catch Can, Tint (all windows), Timbren helpers
Old 12-24-2010, 07:57 AM
webhair webhair is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport - Crew Cab
Rep:30
webhair is on a distinguished road
So does the Timbren set up replace the stock springs or are they just additionals?
Old 12-24-2010, 08:18 AM
CHVYKLR's Avatar
Rep:252
they replace the yellow bumpstops.
