Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 12-21-2010, 08:51 PM
searsda searsda is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Ram 2500 5.9
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
searsda is on a distinguished road
Default turbo boost
I just bought a 06 ram with the cummins in it. I have a intake and exhaust with the edge juice. when i put my foot in it the boost hits about 38-40 and the edge alert me. What is the high end on the boost for the cummins
Old 12-23-2010, 01:06 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
With no other mod's I think your close to the high end now.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected.
Semper Fi Forever
Old 12-23-2010, 01:38 PM
I push the skinny pedal
Rep:3277
The 5.9L can handle 45lbs, after that you'd want to get a set of head studs to keep the head planted. Stock, I wouldn't put much more than 40psi to it, and after that I'd also look at getting a high ram on there to replace the stock intake elbow.
Kurtis
Old 12-23-2010, 08:00 PM
Thanks for your help. Will that high ram intake help lower the boost.
Old 12-24-2010, 01:03 AM
Rep:3277
The high ram doesn't lower the boost, it allows it to move more unrestricted into the intake manifold. If you compare an aftermarket one to the stock, the stock intake elbow has 2 sharp bends, which restricts the flow, where as the aftermarket has a nice sweep. If you're getting higher than normal boost (which is not always a bad thing as long as you're not running lean) you may have a wastegate issue, but those numbers don't worry me at all.
Kurtis
Old 12-24-2010, 09:58 AM
Thanks for your help with this issue. I am sure i will have more qestions later. Have a Merry christmas and a happy new year.
Old 12-24-2010, 12:40 PM
Pull Ya's Avatar
Rep:365
IMHO if you are consistantly over 40 lbs boost I would look for a different turbo and be prepared to do some internal engine work. I'd rather be safe than sorry--but thats just me.
Jay
Semper Fi Forever
