Need some input here, please. 2002 Dodge Ram 1500 5.9 v8 Slt. - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 01-15-2011, 07:25 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Post
Originally Posted by baseballfreakjc View Post
took it to autozone today, got a check engine light scan came up code p0205. Says i have a problem with my fuel injector 5, it reads fuel injector circuit condition-injector 5 explanation.
Not sure if you tried this yet but have you tried replacing injector 5? Maybe the issues with the internal parts of the injector thats why code still pops up wit new ecm.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 01-15-2011, 11:43 PM
wills360mag wills360mag is offline
Vehicle: 2002 dodge ram 4x4
wills360mag is on a distinguished road
you can get one on ebay from the auto computer exchange for $225 or they will repair your old ecu for $125. iv never used them but a friend of mine got an ecu for his dakota r/t from them and it runs like a top. hope that helps
Old 01-20-2011, 08:36 PM
baseballfreakjc baseballfreakjc is offline
baseballfreakjc is on a distinguished road
I havent replaced fuel injectors yet, my mechanic says they are running fine, could a weak battery be making me run like shit? My battery dies real fast, it might be the stock one though, it is a 2002.
Old 01-26-2011, 10:25 PM
anyone have a solution for me, ive installed a new ecm and still same codes p0205 and p0206. What else should i be looking for ,maybe a bad piston?
Old 02-10-2011, 12:25 AM
Default soo
truck has been off the road for about 2 months or so now, checked most of the stuff, kinda narrowing this problem down to either a sensor, or valve springs so i've read.
Injectors swappped out, no new codes.
New Reman Pcm, still got same codes.
ohmed all injector wires, came up fine.
Truck doesn't idle, stalls out gotta keep on the gas.
VERY poor gas mileage, prolly 5-6 mpg.
Friend says The 02 sensor wires could be touching, and causing this or maybe a bad 02 sensor, but could i get this without an 02 code??
Or what about valve springs.
Let me know.
Old 02-10-2011, 01:13 AM
Rep:2929
my buddies old Ram had a similar issue, he had sent the ECU off to have it reconditioned, code still reads PIN 19 is bad, he sent it back & they checked it out & sent it back again
he replaced crank sensor & several other sensors
now there is a dodge ram for sale, he gave up
he doesn't have the $$$ to take it to a dealership, so it has sat in the same spot for at least 3 months
Old 02-13-2011, 12:21 PM
Dude, I know. Seriously its been sitting for two months and the dealership wanted another 3 hours to look at it for 300 bucks. I'm like hell no thats my last resort.
I've had 2-3 other mechanics checking it out, nothing yet.
What the hell could it be.
Old 02-17-2011, 07:23 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
I just read through all this. I'm really sorry to hear it. Mine did a similar thing when an O2 sensor went out. I've had to replace 2 of them so far. It makes my truck run terrible and sometimes it will just crap out. You can get a replacement for like $50. Just tryin to help, man.
Old 02-19-2011, 08:29 PM
Did you get the same codes dude, 205 and 206?? Because I replaced my TPS sensor, checked all the wiring in the injectors getting steady 13 volts outta them, and now im leaning towards a clogged fuel filter. But if you got the same codes as me, I might get 02 sensors.
Old 02-20-2011, 12:16 AM
jcasey10's Avatar
Rep:869
Nope sorry. Mine were 420 and 442.
