Old 12-22-2010, 10:27 PM
TheDon's Avatar
TheDon TheDon is offline
Vehicle: 2012 6.7 cummins 2500 mega cab
Trim Level: big horn
Rep:15
TheDon is on a distinguished road
Default Dodge 1500 not good for towing as advertised.
I have a 2010 Ram 1500 Hemi and blew the tranny towing 6000 lbs. The truck only has 9k on it when it went three weeks ago. They rebuilt the tranny and I had to wait for parts from Detroit. The mechanic and salesman both said if I keep towing with it,its not going to last.But my argument is that Dodge advertises it can haul up to 10,450lbs. and I was only doing 6k...4k under maximum. So I requested them to get me out of the 1500 Hemi and into a Cummins 6.7 and they agree but I have to cough up $$$..is this right?? The trailer btw is a 20 foot enclosed with scaffolding inside of it. I weighed it 3 times and the numbers don't lie...it was 6k.
2012 White Dodge ram 2500 6.7 Cummins HO. BDS 8'' long arm lift, Pure Performance track bar, FOX 2.0's, 20x10 Rockstars, 37" Toyo, BD steering brace, H&S tuner 175hp, H&S cooler delete, GDP Intake horn, boost tube & CCV delete, DPF/Cat delete, S&B CAI, AMP research steps. Timbren bump stops.
Old 12-22-2010, 10:37 PM
sking sking is offline
Vehicle: 2010 2500 4x4 & 2009 1500
Trim Level: SLT X 2
Color: 1 Inferno Red 2 Dark Brown
sking is on a distinguished road
Are you towing that weight everyday?
TheDon's Avatar
Rep:15
No,maybe once every two weeks.
Old 12-22-2010, 10:50 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Here is a link to the Body Builder's guide. It shows what your truck should be able to tow based on how your truck is configured. http://www.dodge.com/bodybuilder/year.pdf
That 10,450 is an absolute max based on a specific configuration.
Brian:
Old 12-22-2010, 10:55 PM
Rep:2657
the transmission in the Ram 1500, 2500, & up ??
DEG 6-Speed Manual Transmission - ($1,170)
Manual six-speed transmission G56; 3.730:1 axle ratio; Excludes: [DMF] 4.10 Axle Ratio And [DG7] 6-Speed Automatic 68RFE Orion Transmission And [DGQ] 5-Speed Automatic 545RFE Transmission
DG7 6-Speed Automatic 68RFE Orion Transmission - $405
Automatic six-speed transmission with lock-up, electronic control and shift lever on column 68RFE; 3.420:1 axle ratio; Requires: [ETJ] 6.7L Cummins Turbo Diesel Engine; Excludes: [DMF] 4.10 Axle Ratio And [DEG] 6-Speed Manual Transmission And [DGQ] 5-Speed Automatic 545RFE Transmission
DGQ 5-Speed Automatic 545RFE Transmission - $0
Automatic five-speed transmission with lock-up and electronic control 545RFE; Automatic drive indicator on dashboard; Requires: [EZC] 5.7L HEMI V8 VCT Engine; Excludes: [DEG] 6-Speed Manual Transmission And [DG7] 6-Speed Automatic 68RFE Orion Transmission
the 2500 Ram diesel
ETJ 6.7L Cummins Turbo Diesel Engine - $6,100
6,690 cc 6.7 liters in-line 6 front longitudinal engine with 107.0 mm bore, 124.0 mm stroke, 17.3 compression ratio, cast iron block, cast iron head, overhead valve and two valves per cylinder ETJ; Diesel fuel; One intercooled turbo compressor; Diesel direct injection fuel system; Block heater; 5.5 gallon main diesel fuel tank 4.6; Weights: gross vehicle weight rating (lbs) 9,000 and max payload (lbs) 3,495; Diesel exhaust brake; Powertrain warranty: duration (months): 60; Power: 261 kW , 350 HP SAE @ 3,013 rpm; 650 ft lb , 881 Nm SAE @ 1,500 rpm; Tow hooks; Heavy duty battery; Requires: [DEG] 6-Speed Manual Transmission; Or [DG7] 6-Speed Automatic 68RFE Orion Transmission; Excludes: [EZC] 5.7L HEMI V8 VCT Engine And [BCQ] Battery - 750 AMP (Fleet)
http://www.automobilemag.com/am/2009...s_options.html
Old 12-22-2010, 11:17 PM
Trim Level: SLT X 2
I think you simply had a bad transmission. I have a 2500 4x4 Hemi and I tow a 8000 pound travel trailer and have towed it around 6000 miles with no problem. My truck has 9200 miles on it now. I do believe we have the same transmission.
Old 12-22-2010, 11:22 PM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
What gear ratio do you have. 3:21 3:55 3:92?
Aepowell Sherman,TX.
Old 12-22-2010, 11:24 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
Nice link RootBeer! According to the chart my Ram is good up to 8900 lbs....Not bad IMO.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 12-22-2010, 11:36 PM
I agree...this is well under the max. I wonder why the dealer would say such a thing. Total BS!
Old 12-22-2010, 11:40 PM
Rep:2657
You could stop by a transmission shop in your area & ask for a technician that is familiar with these transmissions what they know about towing with them, if they are not too busy, they should be able to help you
The RFE is an automatic transmission family from Chrysler. The name refers to its Rear wheel drive design and Full Electronic control system.
applications, ( looks like they have been around for a while )
545RFE
2001 Jeep Grand Cherokee (4.7L, 4.7L H.O., 5.7L Hemi)
2002-2007 Jeep Liberty (Diesel applications)
2003 Dodge Ram (3.7L, 4.7L, 5.7L Hemi)
2003 Dodge Dakota (4.7L, 4.7L H.O.)
2003- Dodge Durango (4.7L, 5.7L)
2006- Jeep Commander (4.7L, 5.7L Hemi)
http://en.wikipedia.org/wiki/Chrysler_RFE_transmission
