Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 12-23-2010, 05:43 PM
TheDon's Avatar
TheDon TheDon is offline
Vehicle: 2012 6.7 cummins 2500 mega cab
Trim Level: big horn
Rep:15
TheDon is on a distinguished road
I believe its a 3:21 I'm not 100% but like Sking said maybe it was a bad tranny,but if it happens one more time they said they would step up and help so I guess I'll give it one more shot and see what happens. The motor is plenty strong,it accelerates with the load with no problem...pretty impressive.
2012 White Dodge ram 2500 6.7 Cummins HO. BDS 8'' long arm lift, Pure Performance track bar, FOX 2.0's, 20x10 Rockstars, 37" Toyo, BD steering brace, H&S tuner 175hp, H&S cooler delete, GDP Intake horn, boost tube & CCV delete, DPF/Cat delete, S&B CAI, AMP research steps. Timbren bump stops.
Old 12-23-2010, 05:54 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Those 3.21s could be part of if not the problem. They're great for mpg but they aren't great for towing/power/torque. Were it me, I'd see if the dealer would swap them out for 3.92s for free.
I agree though, it could be just a bad trans too.
Brian:
Old 12-23-2010, 10:41 PM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
The 3:21 gear is only rated to pull 5800 lbs and that's with 17 inch wheels.
Aepowell Sherman,TX.
Old 12-23-2010, 11:09 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
I would recheck your truck to a towing guide. I am suprised someone at the Service department didn't run those numbers.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 12-24-2010, 12:11 AM
awful knawful awful knawful is offline
Vehicle: 2009 RAM 1500 CC 4X4
Rep:24
awful knawful is on a distinguished road
My 09 CC with HEMI, 20" wheels and 3.55s is good for 6400lbs, thats it.
Old 12-24-2010, 08:48 AM
deepblue's Avatar
deepblue deepblue is offline
Trim Level: Quad Cab Sport
Rep:65
deepblue will become famous soon enough
I have the 3.92 rear end and have been pulling my 8k travel trailer with no issues. About 8k miles on the truck (total) so far. When I bought my truck, I told the dealer I needed to pull up to 9k - they assured me my setup would be fine.
Build Date: MDH:052720 [May 27th (Thursday), 8PM -- 2010]
2010 RAM Sport - Deep Water Blue, 3.92 Gears, Flowmaster 40 Series, Volant CAI w/PowerCore, BedRug, BakFlip F1, Bilstein B6 HDs
-cc
Old 12-24-2010, 09:20 AM
Rep:4192
Great link Brian, thanks for posting that!
Old 12-26-2010, 05:06 PM
Taxpayer Taxpayer is offline
Trim Level: TRX4
Color: Blue
Taxpayer is on a distinguished road
What you are saying is your trans. went bad so why go to a diesel? Sounds like it's not your engine's fault.
Old 12-26-2010, 05:16 PM
Color: RootBeer
Rep:1287
The diesels have a heavier duty trans. But in this particular case, they load being pulled was more than the design specs for the truck.
Brian:
Old 12-26-2010, 05:46 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
If you're running 3.21s and towing that much a simple gear swap will solve the problem. Go down to your local 4x4 shop and have them throw a set of 4.10s in it and you'll never look back. Like RB said...too much of a load for the way the truck is set up (gear wise). A diesel would solve the problem but at a hugh cost for such a small amount of weight. The 2500/3500 gas motors use the same trans as the 1500 so IMHO the trans isn't the problem when the towing capacities are adherred to.
