Old 12-26-2010, 08:48 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
ive said it before....if you expect your 3.21 equipped truck to be a tow monster youre sadly mistaken......your trucks biggest problem lies between the steering wheel and seat.....you equipped your truck improperly then didnt heed the warnings it gave you while using it (trans overtemp!)....id bet you killed the front pump and converter.....
5000lbs is max towing for your truck as equipped.........10450lbs is only for properly equipped trucks with 3.92 gears
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-27-2010, 10:56 PM
NumberCruncher NumberCruncher is offline
Vehicle: 2013 QC Bighorn Ram
Color: Max Steel
NumberCruncher is on a distinguished road
Originally Posted by awful knawful View Post
My 09 CC with HEMI, 20" wheels and 3.55s is good for 6400lbs, thats it.
That was the first year with the coil link suspension yes? If so, I know they were rated quite a bit lower than the 2010 and 2011 Ram's. Not sure why.
BTW, there are a few of those nasty internet rumors about Ram's not towing as well as a truck with leaf suspension. Any truth to this? I am still deciding between a Ram and another truck.
NC
Old 12-28-2010, 02:23 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
NC
believe it or not the 09 rams were rated by dodges own standards which are alot more stringent then ford/chevy.....for 2010 and up an industry standard what set forth to equalize comparisons.....lol.....so dodges weight rating by the new standard set forth went up.....guess who's went down
but as stated before...if youre gonna tow get the truck equipped right....3.92 gears are a must if you plan to tow over 5000lbs......properly equipped a 1500 ram can tow 10,450lbs......
Old 12-29-2010, 01:01 AM
HEMI5150's Avatar
HEMI5150 HEMI5150 is offline
Vehicle: 2010 Dodge Ram Quad 4X4
Trim Level: SPORT
Color: Black Pearl
Rep:35
HEMI5150 is on a distinguished road
EXACTLY....!!!!!!!!!!!!!!!!!!!!!!!
You might be able to bullshit your way to the top, BUT, it wont keep you there
Never believe what you hear, and only half of what you see
Old 12-29-2010, 01:42 AM
Rec 26's Avatar
Rec 26 Rec 26 is offline
Location: El Paso, TX via Centereach, NY, Vieques, PR, and San Antonio, TX
Vehicle: 2014 RAM 3500 Crew Cab Dually
Trim Level: Tradesman
Color: Bright White Clear Coat
Rep:71
Rec 26 will become famous soon enough
Send a message via AIM to Rec 26 Send a message via MSN to Rec 26 Send a message via Yahoo to Rec 26
NC
The only vehicle with any form of wheels that can haul the heaviest loads possible is a train box car or container carrier. All of those use spring suspension. Not leaf.
Hope that answers your question some what....
2011 Ram 1500 Big Horn Quad Cab "SRT Hauler Mark I" (traded in)
2014 RAM 3500 Tradesman Crew Cab "SRT Hauler Mark III"
Old 12-29-2010, 08:56 AM
rking300 rking300 is offline
rking300 is on a distinguished road
Yeah I always watch the trannys temp. I tow once a month a rock crawler and trailer combined weight of a bout 5K fo 3hrs + straight thru and (knock on wood) havent had any issues. Though I also have the 3.92 gears.
Old 12-30-2010, 12:35 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
no worries there......3.92 geared trucks can tow alot more then that....
plus it takes a little common sense.......i pulled a 3 axle dove tail trailer from new orleans to hobbs new mexico and back with that 240 wheelbase dragster you see in my sig (on said trailer) with a 2003 ram with a 4.7 and 3.92 gears.....never missed a beat,never went under 65 and never had a trans problem.....damn trailer weighs 5000lbs....so with tool box,car and other b/s easy 10,000lbs......
Old 12-30-2010, 12:39 AM
Color: Max Steel
Where is the Tranny temp gauge? I assume the center cluster but I didn't notice it when I test drove a Ram about ten days ago.
NC
Old 12-30-2010, 12:44 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
NC
Yes, it is in the center information center (EVIC aka Electronic Vehicle Information Center). Scroll through the menus.
Brian:
Old 12-30-2010, 01:01 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
This exact scenario is what gets people to thinking that these RAM's aren't what they say. I personally am very pleased with mine and I have been a FORD man all my life, this truck is performing beyond my expectations. Although I did choose the setup I wanted for future endeavors, like towing. A gear setup is a critical part of the truck if your planning on towing heavy or on a regular basis, IMO the OP fell victim of not knowing and the dealership is at fault for not asking and educating the buyer.
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
