Old 12-23-2010, 03:55 PM
epeitz's Avatar
epeitz epeitz is offline
Vehicle: 2009 Ram
Rep:59
epeitz will become famous soon enough
Default Recon Tailgate bar
I have a recon tailgate bar and it is hard wired in. The running light on it will not work. The turn signals and brake light work, but not if the running/head lights are on. Does anyone have any idea what could be wrong? I am pretty sure it is wired correctly. Any help would be appreciated.
Old 12-23-2010, 04:14 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
Bad splice?
Broken wire after splice?
Find the running light wire use a jump-it or another 12volt source and see if it lights up. If it doesnt light, you may have a broken wire closer to the unit. Led's normally dont burn out or break easily.
My guess is a bad connection/splice/ground or wired to the wrong wire you thought was the running light. (not doubting you, just covering the bases!)
Good luck.
Old 12-23-2010, 04:57 PM
epeitz's Avatar
Vehicle: 2009 Ram
Rep:59
Originally Posted by Chili1K View Post
Bad splice?
Good luck.
I actually re-wired the end on it and plugged it directly into the 4 pin trailer plug.....Same thing. I just dont know if I have a short in the wiring somewhere or if the light bar has a short in it. Thanks for the help though.
Old 12-23-2010, 07:05 PM
Chili1K's Avatar
Trim Level: TRX4
Rep:1092
Check for power on ur hitch harness.. maybe its not the bar. maybe that running light wire is defective in the harness (unlikely but check anyway.)
If you rewired the plug, apply voltage straight to the running light lead on the bar. see what happens.
Old 06-22-2011, 08:41 PM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Power Wagon
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
I am having the same problem. I just now read this far in the posts and already posted a the same question. When I turned off my fog lights it kind of worked. Have you had any luck on this issue? I see it has been a few months.
