Old 12-24-2010, 11:07 PM
retiredconowjeeping retiredconowjeeping is offline
Vehicle: 2009 Dodge Ram crew cab 4x4
Color: silver
retiredconowjeeping is on a distinguished road
Default TPMS Prblems
Changed my tires the other day and met up with the tire pressure monitor system. What kind of crap are they using on those long nuts that thread to the stem. They cost 3 bucks at Dodge and they all crack while changing tires no matter how careful you are! Once cracked they produce a slow leak that takes days to figure out. Arrrgh!
Old 12-25-2010, 11:53 AM
Resident Technician
Rep:1915
Not sure what you're talking about. I've never had a problem breaking sensors and I've changed a lot of tires with them.
Old 12-25-2010, 11:58 AM
hmmm...never had that problem on my TPMS units either.
Old 01-12-2011, 07:20 PM
bigg john bigg john is offline
Vehicle: 012 3500 dwd crew cab 8' bed
Trim Level: bighorn
bigg john is on a distinguished road
i did tires for 20 years, when you break the bead of the tire start 180 degrees from the valve both front and rear of tire,face up looking at the tire start with the iron just after the valve while pushing down on opposite side of the tire. i hope that this will help
bigg john
Old 01-14-2011, 06:16 PM
moparornocar72's Avatar
Rep:630
^ what he said, I don't even come close to the sensors, Last time someone in the shop did they were at least $45 a piece. Most vehicle have them right behind the stem unless it's a Ford which then it is directly across on a band (stupid design) but the new Fords are underneath valve stems now.
14.268 @ 95 MPH Full Trim
Old 01-18-2011, 09:46 PM
byelland1 byelland1 is offline
Vehicle: 2012 dodge ram 1500
Trim Level: outdoorsman
Color: deep cherry red
byelland1 is on a distinguished road
your talking about the rebuild kit they have for the tpms, either they are overtorquing the hex nut, or they dont know what they are doing.
