Old 12-24-2010, 11:45 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Unhappy Bad vibrations...
I just got my new wheels on and was driving out for christmas eve. Well, took the first corner and felt this really odd vibration. I can hear and feel it a lot going through corners no matter the speed, and just barely when I'm driving straight. I think it sounds like a warped rotor, but I wasn't getting any vibrations when I was slowing down. I don't think it could be an off balance tire either, because it sounds more like metal rubbing. Help?
Old 12-24-2010, 11:47 PM
Wheels rubbing on the brake caliper? Wheels not mounted flush on the hub? Wheels and tires rubbing on the wheelwell?
Old 12-24-2010, 11:50 PM
jcasey10's Avatar
Rep:869
Well, I stayed with the same size wheel 17x9 and the tires are the same tires. Although, when they mounted them, I had them turn the whitewalls in and they put my back tires on the front. I don't understand how they could rub the wheelwell with the same tires.
Old 12-25-2010, 12:04 AM
That's good info you didn't share the first go around here.
What offset wheels did you go with? Did you use spacers? Details please. What's different from your previous set of wheels?
Old 12-25-2010, 12:07 AM
jcasey10's Avatar
Rep:869
Sorry about that.
My new wheels have a -12mm offset, and I'm not quite sure about the old wheels. I know they were similar though. My tires stick out just the same as they used to.
Old 12-25-2010, 12:10 AM
jcasey10's Avatar
Rep:869
I didn't use spacers previously, and I'm not now. The tires are 285/70/17 and my truck is leveled, so I don't think its the tires rubbing.
Before I had the wheels changed out, my truck would shake really bad when braking. I could tell my rotors were getting warped, but kept putting it off. Dumb of me. I'm going to jack the truck up tomorrow, and roll the tires to see if they're wobbling at all. And I'll probably take the wheels off and check the rotors and pads.
Old 12-25-2010, 12:13 AM
So this condition existed, to an extent, before you swapped out wheels? Interesting. The only other parameter that could have changed is the torque spec. A higher lb/ft spec would definitely excaberate a warped rotor problem.
I think you are on the right track. I'd pull a rotor and check it for runout.
Old 12-25-2010, 12:18 AM
jcasey10's Avatar
Rep:869
That makes sense. Thanks for the help, Maddog. I'm really hoping O'Reillys will be open, but I don't think I'll have much luck.
Old 12-25-2010, 12:31 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
While they've got the wheel off on the front, have them check the ball joints and upper and lower control arms.
Brian:
Old 12-25-2010, 03:18 AM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
I think he's gonna do the work himself RB.
But anyway, I agree with Michael. Check your rotors.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
